What is the negative sign in Faraday's Law/EMF with respect to?
In summary, the negative sign in Faraday's Law is due to the conventional right-handed coordinate system, and it is necessary in order to depict the correct direction of the induced circular E field in relation to the direction of the magnetic field. This negative sign is also present in the equation for electromotive force, which is derived from Faraday's Law.
etotheipi
A common definition seems to be that emf is an electrical action produced from a non-electrical source. So, for instance, a voltage might develop across a resistor due to a gradient of electric charge across the resistor, however this isn't an emf since the source is electrostatic in nature.
As an example, the voltage across an inductor might be reported as ##L\frac{di}{dt}## or ##-L\frac{di}{dt}## depending on our choice of sign convention, however the emf is only ever written as ##\mathcal{E} = -L\frac{di}{dt}##. This is because there is a minus sign in Faraday's law. I understand the operational definition of this negative sign (Lenz's law), however don't understand why it needs to be there from a mathematical perspective. Negative with respect to what? In essence, I'm confused as to why there is only ever one correct sign for the emf. Thank you!
I believe the reason for this negative sign is to satisfy Faraday's equation.
## ∇×\vec E = -\frac {φ \vec B} {φt} ##
Note that all the E, curl E and B are vectors, and the direction of the curl is the axis of rotation, as determined by the right-hand rule , therefore, in order to depict the correct direction of the induced circular E field, the direction of curl E must be opposite to the direction of B, so there must be a negative sign.
In other words, if we can redefine the curl operation to follow the left-hand rule instead of the right-hand rule, then it seems that the minus sign should be removed. 🤔
Likes etotheipi
Ah okay, so the negative sign in Faraday's Law is due to the conventional choice of a right-handed coordinate system, and then we can just say
$$\nabla \times \vec{E} = -\frac{\partial B}{\partial t}$$ $$\int_{S} \nabla \times \vec{E} \cdot d\vec{A} = -\frac{d}{dt} \int_{S} \vec{B} \cdot d\vec{A}$$ $$\oint \vec{E} \cdot d\vec{s} = -\frac{d}{dt} \int_{S} \vec{B} \cdot d\vec{A}$$ which is just $$\mathcal{E} = - \frac{d\Phi}{dt}$$
Likes alan123hk
Related to What is the negative sign in Faraday's Law/EMF with respect to?
1. What is the significance of the negative sign in Faraday's Law?
The negative sign in Faraday's Law indicates the direction of the induced electromotive force (EMF) or voltage. It signifies that the induced EMF will be in the opposite direction of the change in magnetic flux.
2. Why is there a negative sign in Faraday's Law?
The negative sign is a result of the Lenz's Law, which states that the induced current will always flow in a direction that opposes the change in magnetic flux. This opposition is represented by the negative sign in Faraday's Law.
3. Does the negative sign in Faraday's Law affect the magnitude of the induced EMF?
No, the negative sign does not affect the magnitude of the induced EMF. It only indicates the direction of the induced EMF.
4. How does the negative sign in Faraday's Law relate to the direction of the induced current?
The negative sign in Faraday's Law is directly related to the direction of the induced current. It signifies that the induced current will flow in the opposite direction of the change in magnetic flux.
5. Can the negative sign in Faraday's Law be ignored?
No, the negative sign in Faraday's Law cannot be ignored. It is an essential part of the equation and indicates the direction of the induced EMF and current. Ignoring the negative sign would result in incorrect calculations and predictions.
  • Electrical Engineering
