What is the nth term of this matrix?
In summary, the person is looking for the general terms of a matrix and wants to find A^{50}. They have tried diagonalization but are stuck. Cayley-Hamilton theorem may be useful but is not required.
inverse
Hello,
I would like to know what are the nth terms of the following matrix,
[itex]\begin{pmatrix} 2 & 1 & 1\\ 2 & 3 & 2 \\ 1 & 1 & 2\end{pmatrix} = A^{1}[/itex]
I want find the general terms of the matrix, and then can find [itex]A^{50}[/itex]
Thank you very much for your help
a greeting
The standard method is to diagonalize, right? So have you done it? Where are you stuck?
Exactly, I have used diagonalization but as I'd like to know if there is also the possibility to find the nth term of the matrix calculating of this form: A ^ 1, A ^ 2, A ^ 3 ... until being able to find some relation.
you think is too long or too compiled by calculating power and is it not better to use diagonalization?assuming that the matrix is not diagonizable, how you would calculate the nth term?
The easiest method without diagonalization is using the Cayley-Hamilton theorem. So, did you find the characteristic polynomial??
inverse said:
Hello,
a greeting
Just for curiosity: what exactly do you call "nth terms of matrix" to?? Seems like other responders know, but I still have no idea.
DonAntonio
DonAntonio
Yeah, I have no idea either. I just assumed he wanted to find the nth power of the matrix.
Allow me to expand on what Hurkyl was thinking.
I put {{2,1,1},{2,3,2},{1,1,2}} into wolfram alpha (after typing "matrix" into find grab the format) and got [itex]A=SJS^{-1}[/itex]. Then [itex]A^2=(SJS^{-1})^2=SJ^2S^{-1}[/itex] (check why that is true). I want you to find what [itex]J^2[/itex] is. Then find what [itex]A^n=(SJS^{-1})^n[/itex] is using the same idea.
note: wolfram alpha will tell you what S and J are.
Cayley Hamilton theorem looks interesting, and probably has great applications, but I don't think you'd want to use it here, you'd be dealing with a 50th degree polynomial right?
Yes, I want to find the nth power of the matrix without diadiagonalization.
It is possible with Cayley–Hamilton theorem?
Exactly
No, you would end up with something like
[tex]A^{50}=aA^3+bA^2+cA+d[/tex]
of course, to get it in that form, you'd have to calculate somewhat. Or you would have to be lucky and notice a pattern.
Why don't you want to use diagonalization??
I have no problem in using diagonalization, I have just curious as you'd calculate if the matrix was not diagonizable
Any matrix that is not diagonalizable can be put into "Jordan Normal Form". It is a little harder to find the nth power of a Jordan Normal Form Matrix but not impossibly so.
Or, as micromass suggested, since this is three by three matrix, its characteristic polynomial is of degree at most 3 and A itself must make that equal to 0. That is, the third power of A can be written as a linear combination of lower powers. And, of course, higher powers of A can be reduced successively to quadratic and lower powers.
Here, [itex]A^3= 7A^2- 11A+ 5I[/itex] so that [itex]A^4= 7A^3- 11A^2+ 5A= 7(7A^2- 11A+ 5I)- 11A^2+ 5A[/itex][itex]= (49A^2- 77A+ 35I)- 11A^2+ 5A= 38A^2- 72A+ 35I[/itex] etc.
You would write it as
A = P(D + N)P^(-1)​
where D is diagonal, N is nilpotent, and D commutes with N (e.g. the Jordan Normal Form that HoI mentioned). When you work out the algebra, you essentially end up with a "Taylor series" centered on D:
f(A) = P (f(D) + N f'(D) + (1/2) N^2 f''(D) + ...) P^(-1)​
which terminates, because N^k = 0 for some k.
A = P(D + N)P^(-1)​
I can already get A^50 whith this, right?
Thanks to all!
FAQ: What is the nth term of this matrix?
What is the nth term of a matrix?
The nth term of a matrix is the value at the nth position in the matrix, counting from the first element in the top left corner. It is also known as the (n+1)th term, since the first element in a matrix is considered to be at position 0.
How do I find the nth term of a matrix?
To find the nth term of a matrix, you need to first identify the pattern in the matrix. This pattern could be in the rows, columns, or both. Once you have identified the pattern, you can use a formula or algorithm to calculate the nth term.
Can the nth term of a matrix be a negative number?
Yes, the nth term of a matrix can be a negative number. This is because a matrix can contain both positive and negative numbers, and the position of the nth term does not determine its sign.
Is there a specific formula for finding the nth term of a matrix?
There is no one specific formula for finding the nth term of a matrix, as it depends on the pattern in the matrix. However, there are common formulas and algorithms that can be used for different types of matrices, such as arithmetic or geometric sequences.
Can the nth term of a matrix be a fraction or decimal?
Yes, the nth term of a matrix can be a fraction or decimal. This is possible if the matrix contains fractions or decimals, or if the pattern in the matrix involves a division or multiplication by a fraction or decimal number.
