What is the optimal fencing for a triangular field?
  • MHB
  • Thread starter Chris L T521
In summary, the optimal fencing for a triangular field depends on factors such as size, terrain, and purpose. Common types of fencing include wire mesh, post and rail, and electric fencing. To calculate the amount needed, measure the perimeter and add a few extra feet. Regular maintenance, such as checking for damage and keeping vegetation trimmed, is important for keeping the fencing in good condition.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: A triangular field is to be enclosed by $p$ feet of fencing so as to maximize the area of the field. Find the lengths of the sides of this triangle.
Hint:
Heron's formula for the area of a triangle with side lengths $x$, $y$ and $z$ is $A=\sqrt{s(s-x)(s-y)(s-z)}$, where $s=\frac{1}{2}(x+y+z)$ is the semiperimeter.
This week's problem was correctly answered by MarkFL and Sudharaka. You can find Sudharaka's solution below.
\[A=\sqrt{s(s-x)(s-y)(s-z)}~~~~~~~~(1)\]
\[s=\frac{1}{2}(x+y+z)~~~~~~~~~~(2)\]
\[p=x+y+z~~~~~~~~~~(3)\]
Using (1), (2) and (3) we get,
\[A=\frac{1}{4}\,\sqrt{p\,\left( p-2\,x\right) \,\left( p-2\,y\right) \,\left( 2\,x+2\,y-p\right) }\]
Now we shall use the second partial derivative test to find the maximum of \(A\) and the corresponding lengths of the sides.
Differentiating with respect to \(x\) and \(y\) we get,
\[\frac{\partial A}{\partial x}=\frac{p\,\left( y+2\,x-p\right) \,\left( 2\,y-p\right) }{2\,\sqrt{p\,\left( 2\,x-p\right) \,\left( 2\,y-p\right) \,\left( 2\,y+2\,x-p\right) }}\]
\[\frac{\partial A}{\partial y}=\frac{p\,\left( 2\,x-p\right) \,\left( 2\,y+x-p\right) }{2\,\sqrt{p\,\left( 2\,x-p\right) \,\left( 2\,y-p\right) \,\left( 2\,y+2\,x-p\right) }}\]
When \(\frac{\partial A}{\partial x}=0\) we have,
\[p=2y\mbox{ or }p=y+2x~~~~~(4)\]
When \(\frac{\partial A}{\partial y}=0\) we have,
\[p=2x\mbox{ or }p=x+2y~~~~~~~~~(5)\]
By (4) and (5) we get two possibilities,
\[x=y=\frac{p}{2}\mbox{ or }x=y=\frac{p}{3}\]
\(x=y=\frac{p}{2}\Rightarrow z=0\). Hence these lengths do not form a triangle. So the only possibility is,
\[x=y=z=\frac{p}{3}\]
We can also show that,
\[D\left( \frac{p}{3},\frac{p}{3}\right) = A_{xx}\left( \frac{p}{3},\frac{p}{3}\right) A_{yy} \left(\frac{p}{3},\frac{p}{3}\right) - \left( A_{xy}\left(\frac{p}{3},\frac{p}{3}\right) \right)^2=\frac{9}{4}>0\]
and
\[A_{xx}\left(\frac{p}{3},\frac{p}{3}\right)=-\sqrt{3}<0\]
Therefore by the second partial derivative test, \(A\) has a maximum at \(x=y=z=\frac{p}{3}\).
FAQ: What is the optimal fencing for a triangular field?
The optimal fencing for a triangular field depends on several factors such as the size of the field, the terrain, and the purpose of the field. However, there are some general guidelines that can help determine the optimal fencing for a triangular field.
What are the factors to consider when determining the optimal fencing for a triangular field?
The size of the field, the terrain, and the purpose of the field are important factors to consider when determining the optimal fencing for a triangular field. Other factors to consider may include the type of animals or plants that will be contained within the field and any local regulations or restrictions.
What are some common types of fencing for triangular fields?
Some common types of fencing for triangular fields include wire mesh fencing, post and rail fencing, and electric fencing. Each type of fencing has its own advantages and disadvantages, so it is important to consider the specific needs of the field before choosing a type of fencing.
How do I calculate the amount of fencing needed for a triangular field?
To calculate the amount of fencing needed for a triangular field, you will need to measure the perimeter of the field. This can be done by measuring each side of the triangle and adding them together. It is also important to add a few extra feet to account for corners and any necessary gates.
What are some tips for maintaining fencing in a triangular field?
Regular maintenance is key to keeping fencing in good condition. This may include checking for any damage or wear and tear, repairing or replacing damaged sections, and keeping the surrounding vegetation trimmed to prevent damage to the fence. It is also important to regularly inspect and maintain any gates or other entry points.
