Daystar
- 6
- 6
- How did you find PF?
- Google Search
Hi all.
I wanted to make a large scale map of the solar system with all the orbits from Mercury to Pluto to scale on the same sheet. I'll try to get pieces of the orbits of Makemake, Haumea and Eris on the edges too.
All the images I had seen showed either the inner system or the outer system, understandably because the diameter of Pluto's orbit is about 100 times larger than the orbit of Mercury. Then I wanted to indicate the orientation of the plane of most planets related to the plane of Sol's rotation around the Milky Way.
While researching that I stumbled on "Fizixfan's" thread in the Astronomy and Astrophysics forum called "Orientation of the Earth, Sun and Solar System in the Milky Way". I then spent several enjoyable hours reading through the thread, from when it started in October 2016 until the last post in September 2019. I was very impressed with the explanations and descriptions of the structure and dynamics of our galaxy, nearly all expressed in simple language with great diagrams, and with the way the discussions build nicely in a generally constructive way.
And of course I learned a lot, not just about the question that I originally wanted answering but also about many other aspects of the Earth's position in the Solar system and the system's position in our galaxy.
I will post a picture of my "map" when it is finished. I have just learned how to draw elipses, worked out the scale (1cm = 100 million km) and made up the board. I look forward to exploring more of this forum as well as the others.
