What is the paradox in the EPR paradox?
In summary, the conversation discusses two possible understandings of how a stationary particle separates into two particles A and B. One understanding suggests that it is possible to independently measure the momentum of A and the position of B, violating Heisenberg's uncertainty principle. The other understanding suggests that by measuring the momentum or position of A, one can deduce the corresponding property of B, even if they are far apart. The conversation also explores the paradox of quantum mechanics and how it explains the correlation between distant outcomes. It concludes that there is no contradiction if one accepts the statistical interpretation of quantum theory and works with normalizable states.
bksree
77
Hi
Which of these understandings is correct ?
A stationary particle separates into 2 particles A & B
Is it that :
(a) One can independently measure accurately to the desired accuracy the momentum of A and the position of B and thus obtain both position AND momentum of either particle thus violating Heisenberg's uncertainty principle (Is this really a violation of Heisenberg's uncertainty principle since no simultaneous measurement of momentum and position is done here?)
OR is it that
(a) one can measure accurately to the desired accuracy the momentum or position of particle A and deduce instantaneously the value of the corresponding property of B (even though B is several light years away).
What is the need to assume instantaneous transmission of information because from the principle of conservation of momentum if pA is measured, then pB is known)TIA
The "paradox" is that QM says that the observables do not have defined values until they are measured. The question is then how nature correlates distant outcomes.
There is no paradox, if you accept quantum theory in its (minimal) statistical interpretation. In the original EPR example the momenta of the decayed particles are entangled due to momentum conservation in the particle decay. The total momentum ##p_1+p_2## and the relative position ##x_1-x_2## are compatible observables and there's no contradiction to the uncertainty relations between the single-particle momenta and positions whatsoever. Of course one has to work with normalizable states, i.e., wave packets. Neither momentum nor position (generalized) eigenvectors are representing proper (pure) states.
The same holds for Bohm's version of the paradox using entangled spins of partilces. The only difference is that it is a bit simpler to formulate, because the spin eigenstates are proper (pure) states, i.e., angular momenta have only discrete spectra.
Related to What is the paradox in the EPR paradox?
1. What is the EPR paradox?
The EPR paradox, also known as the Einstein-Podolsky-Rosen paradox, is a thought experiment proposed by Albert Einstein, Boris Podolsky, and Nathan Rosen in 1935. It challenges the principles of quantum mechanics and suggests that there may be hidden variables at play in the behavior of particles.
2. What is the paradox in the EPR paradox?
The paradox in the EPR paradox arises from the fact that quantum mechanics predicts that two particles can be entangled, meaning that their properties are correlated even when they are separated by large distances. This seems to contradict the principle of locality, which states that no influence can travel faster than the speed of light.
3. How does the EPR paradox challenge quantum mechanics?
The EPR paradox challenges quantum mechanics by suggesting that there may be hidden variables at play in the behavior of particles. These hidden variables would determine the properties of particles and explain their seemingly random behavior, thus contradicting the probabilistic nature of quantum mechanics.
4. Has the EPR paradox been resolved?
The EPR paradox has not been fully resolved, but it has been extensively studied and debated by scientists. Some have proposed theories that could potentially explain the paradox, while others argue that the paradox is a result of a misunderstanding of quantum mechanics.
5. What are the implications of the EPR paradox?
The EPR paradox has significant implications for our understanding of the fundamental nature of reality. It raises questions about the role of observation and measurement in quantum mechanics and the possibility of hidden variables influencing the behavior of particles. It also has practical implications for technologies such as quantum computing and cryptography.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
9K
  • Quantum Physics
