What Is the Pattern in This Number Sequence?
  • Thread starter Alexx1
In summary, the given sequence has a formula of n^2 for even indices and 1 for odd indices. This can also be written as (1 - (-1)^n)/2 + n^2*(1 + (-1)^n)/2. Another possible formula is (S(n/2) - 1)*(1 + (-1)^n)/2 + 1, where S(n) is the sequence 4, 16, 36 for n = 1, 2, 3.
Alexx1
86
Can someone help me with this sequence?
1 4 1 16 1 36
If I only look at the odd numbers it's: n^2
But I don't know how they get to '1'..
Mathematics news on Phys.org
My answer would be to construct a step function for the y power term in x^y. The step function is a continuous representation of the integral of kronecker/dirac delta. The condition of the step is 'evenness' or 'oddness'.
Eg. If your series were,
1 8 1 64 1 216..
then my solution would be
[tex]
n^{g};
[/tex]
[tex]
g=\frac{2}{1+ exp(P*(3*binx_n -1)};
[/tex]
where binx_n is the last (right-most) digit in the binary representation of n; and P is a very large number (say 1e9). So in your case, the series will be: (read from left to right.. solution from MATLAB for 100 term series)
1 4 1 16 1 36 1 64 1 100 1 144 1 196 1 256 1 324 1 400 1 484 1 576 1 676 1 784 1 900 1 1024 1 1156 1 1296 1 1444 1 1600 1 1764 1 1936 1 2116 1 2304 1 2500 1 2704 1 2916 1 3136 1 3364 1 3600 1 3844 1 4096 1 4356 1 4624 1 4900 1 5184 1 5476 1 5776 1 6084 1 6400 1 6724 1 7056 1 7396 1 7744 1 8100 1 8464 1 8836 1 9216 1 9604 1 10000
So the big question here becomes, is the representation actually continuous (for it to be a nice analytical solution)? The presence of the binary makes that question hard to answer. Obviously, using the binary is an overkill. But there's a ton of ways to flip the exponential's sign given a number is odd or even. Any answer anyone else comes up with (your instructor, maybe), will be reducible to the given form.
Delightful little question. Hope this shows you how to consider such problems.
Edit: Note-My expression is different from what you need! If you want to test your understanding, then try to express this series with a continuous, differentiable expression:
1 4 1 64 1 36 1 512 1 100 1 1728 1 …
1 4 1 16 1 36
So you are starting with [itex]a_0[/itex]? There is nothing at all wrong with:
[itex]a_n= 1[/itex] if n is even, [itex](n+1)^2[/itex] if n is odd.
If you insist upon a single formula,
[tex]a_n= \frac{1- (-1)^n}{2}+ \frac{1+ (-1)^n}{2} (n+1)^2[/tex]
When n is even [itex](-1)^n= 1[/itex] so [itex]\frac{1- (-1)^n}{2}= 0/2= 0[/itex] and[itex]\frac{1+ (-1)^n}{2}= 2/2= 1[/itex]. Then [itex]a_n= 0+ (n+1)^2= (n+1)^2[/itex].
When n is odd [itex](-1)^n= -1[/itex] so [itex]\frac{1- (-1)^n}{2}= 2/2= 1[/itex] and [itex]\frac{1- (-1)^n}{2}= 0[/itex]. Then [itex]a_n= 1+ 0(n+1)^2= 1[/itex].
There are many ways to do this, the most compact one is probably:
[tex]a_{n}=n^{(1+(-1)^{n})},n=1,2...[/tex]
\(\displaystyle a_n= 1\) if n is even, [itex](n+1)^2[/itex] if n is odd.
Thanks!
Thank you very much!
1 4 1 16 1 36
The even members are [itex](2 n)^{2}, n = 1, 2, \ldots[/itex]. The odd ones are always 1.
So, we can write:
[tex]
a_{n} = \left\{\begin{array}{rc}
n^{2}, & n \, \mathrm{even} \\
1, & n \, \mathrm{odd}
\end{array}\right.
[/tex]
You can write it in this form:
[tex]
a_{n} = \frac{n^{2} + 1}{2} + (-1)^{n} \, \frac{n^{2} - 1}{2} = \frac{1 - (-1)^{n}}{2} + n^{2} \, \frac{1 + (-1)^{n}}{2}
[/tex]
It looks to me like there's a different formula for the odd-index elements, with a2n+1 = 1, for n = 0, 1, 2, ...
So, we can write:
[tex]
\end{array}\right.
[/tex]
[tex]
[/tex]
Mine's better! :approve:
I'm not exactly sure, but I can think of a way to get back to the number by.. say...
[tex]\frac{1+(-1)^{n-1}}{2}[/tex]
In this formula, when n is odd, then we have 1, but when n is even we get 0.
So... we could use something like this
[tex](S(n/2)-1).\frac{(1+(-1)^{n-1})}{2}+1[/tex]
seems like it would be an appropriate formula for your problem, where S(n/2) is the sequence 4,16,36 for n=1,2,3.
So if you find a formula for the sequence S(n)=4,16,36 which I couldn't figure out (I'm pretty bad at sequences) then you can find a formula for the sequence you've shown by filling in S(n/2).
And mines probably the worst of all!
But yes, I really like your formula.
Yeah, well, I beat you to it on the other thread. :-p :approve:
That was merely a sub-thread, I rule the main thread! :smile:
FAQ: What Is the Pattern in This Number Sequence?
What is the pattern in this sequence?
The pattern in this sequence is that each number is being multiplied by itself to get the next number. For example, 1 x 1 = 1, 1 x 4 = 4, 4 x 4 = 16, and so on.
What is the next number in this sequence?
The next number in this sequence would be 1 x 16 = 16.
3. How do I continue this sequence?
To continue this sequence, you would keep multiplying the last number by itself to get the next number. For example, 16 x 16 = 256, so the next number in the sequence would be 256.
4. Can this sequence have multiple patterns?
No, this sequence follows one specific pattern of multiplying each number by itself to get the next number. If there were multiple patterns, the sequence would not be consistent.
5. How can I use this sequence in real life?
This sequence could be used in mathematical or scientific calculations, such as calculating exponential growth or determining the area of a square with a given side length. It could also be used in computer programming or data analysis to generate or manipulate data sets.
