holomorphic
- 91
What is the next number?.
7, 16, 25, 34, 43, 52, 61, 70, 77, 106...?
holomorphic said:What is the next number?.
DaveC426913 said:Bah. Saw it right away.
There are a few possible answers, but best answer is 115.
The pattern for finding the next number in a sequence depends on the specific sequence. Some common patterns include adding or subtracting a constant number, multiplying or dividing by a constant number, or following a specific mathematical formula.
To confirm if your answer for the next number is correct, you can use the pattern to check if it fits with the previous numbers in the sequence. You can also use a calculator to see if your answer follows a specific mathematical formula.
No, there can be multiple correct answers for the next number in a sequence. This is because there can be different patterns or rules that can be followed to find the next number. However, some patterns may be more commonly accepted than others.
Yes, you can use guess and check to find the next number in a sequence. This method involves making an educated guess based on the pattern and checking if it fits with the previous numbers in the sequence. If it does not fit, you can adjust your guess until you find the correct answer.
If you cannot find a pattern to determine the next number in a sequence, it is possible that the sequence may not have a clear pattern. In this case, the sequence may be considered random or there may be multiple possible patterns that can be followed.
