What is the physics behind quantum tunneling
In summary, the conversation discusses the concept of quantum tunneling, where a particle has the ability to "hop" through a potential barrier even when the potential is greater than the particle's kinetic energy. This phenomenon is explained by solving the Schrodinger equation, but the question remains about the physics behind it. The experts in the conversation suggest that the particle does not have a localized position and that its energy can fluctuate, allowing it to pass through the barrier. It is also noted that the uncertainty principle plays a role in this process. Ultimately, the conservation of energy is still valid in this scenario, but it may not be as straightforward as in classical physics.
einstein1921
76
Hi, My friends! According to quantum mechanics books ,a particle has some probability hop through the potential even when the potential is large than kinetic energy. They all explain the phenomenon by solving Schrodinger equation. Indeed, the wavefunction doesn't equal 0 behind the potential. But I want to know how the particle go through the potential? What is the physics behind quantum tunneling? I can't accept the explanation in books! Everyone who says something about quantum tunneling would be highly appreciated.
let us talk about it!
best wishes!
PS: I read something about STM. the book says that because of tunneling ,the electron of metal are not confined the inner of surface,that is to say ,electron density don't fall to zero at the surface,but attenuation exp(), I want to know why the electron leaves the metal ,and they have pass the potential barrier!
The physics IS the Shrodinger Equation. There is a lot to think about, but there is no Classical explanation, which is what it sounds like you are looking for. I understand your ambivalence, but Nature does not care what you are willing to accept. The physics behind it is quantum mechanics which does not require localized particles as the system evolves. Sorry.
I think its Heisenbergs uncertainty principle. The smaller a particle is, the less its position in space can be known. As a result, it exists in multiple locations in space.
Can we say the particle tunnel through the barrier instantly or faster than c? We don't know how the particle behind the barrier suddenly appears in front of the barrier? Can it be another phenomena similar to quantum entanglement?
No. Signal propagation speed is always limited by the speed of light. However, it is tricky to say "the particle is at this side right now" - to get the position very precise, the particle needs a large momentum uncertainty, which helps tunneling (and if its energy is large enough, it does not even have to tunnel).
No, you cannot say that. Try finding the momentum of the particle inside the barrier. It is not infinite.
Zz.
Zz.
Yes, I remember it now.
Probability function drops sharply inside the barrier but never zero.
Then only physical explanation can be made this way:
The particle somehow interacts with the potential barrier.
In microscopic world this interaction is possible, but not in macroscopic world.
you means that we can't think the particle as a localized dot, but a unlocalized something!
thank you all!is this ture? when particle is confined in the barrier,according to Heisenberg's uncertainty principle, the momentum will become larger than the potential barrier,even though it doesn't large than the barrier at first! so in essence, the particle's energy still is larger than the potential,so it can hop through the barrier!
PS: the question is if particle's energy increases because of Heisenberg's uncertainty principle, what form of energy is decrease? energy conservation!
From wiki: http://en.wikipedia.org/wiki/Conservation_of_energy#Quantum_theory
Quantum theory
In quantum mechanics, energy of a quantum system is described by a self-adjoint (Hermite) operator called Hamiltonian, which acts on the Hilbert space (or a space of wave functions ) of the system. If the Hamiltonian is a time independent operator, emergence probability of the measurement result does not change in time over the evolution of the system. Thus the expectation value of energy is also time independent. The local energy conservation in quantum field theory is ensured by the quantum Noether's theorem for energy-momentum tensor operator. Note that due to the lack of the (universal) time operator in quantum theory, the uncertainty relations for time and energy are not fundamental in contrast to the position momentum uncertainty principle, and merely holds in specific cases (See Uncertainty principle). Energy at each fixed time can be precisely measured in principle without any problem caused by the time energy uncertainty relations. Thus the conservation of energy in time is a well defined concept even in quantum mechanics.
It's not that the particle has enough energy to get through the barrier,energy fluctuations in the barrier can push the particle through it(by absorbing and emitting).
This is not correct. The particle itself is what has the uncertainty that allows it to appear on the other side of the barrier. Are you aware of what a "barrier" is? It doesn't have to be a physical barrier. For example, there is a barrier in Proton-Proton fusion in the Sun in the form of electromagnetic repulsion between the protons. They shouldn't have enough energy to fuse, as the repulsion is strong enough in a classical sense to keep them apart, however they protons can tunnel through this barrier and fuse. The barrier represents something that the particle couldn't normally do, whether it's tunnel through a repulsive force or out of an attractive one, as in the case of spontaneous nuclear fission.
Drakkith
If it's the particle itself that has the uncertainty then:-
Are you saying that 2 protons in the vacuum of space,have the same chance of tunneling through the barrier,as 2 protons in the middle of the sun?
Funny you should mention that. Our understanding of the nuclear processes that go on in the solar interior depends on making measurements on those same reactions in the lab. If the reaction rates were not the same in both environments, it would be painfully obvious.
Well it certainly isn't classical physics. Someone mentioned the uncertainty principle and the different principles of quantum physics. The difficulty lies in accepting that atoms are more like processes and much less like rocks(i am still struggling as this must hold for larger objects too, but so was Heisenberg and everyone else):
"In modern physics, atoms lose this last property, they possesses geometrical qualities in no higher degree than colour, taste, etc. The atom of modern physics can only be symbolized by a partial differential equation in an abstract multidimensional space. Only the experiment of an observer forces the atom to indicate a position, a colour and a quantity of heat. All the qualities of the atom of modern physics are derived, it has no immediate and direct physical properties at all, i.e. every type of visual conception we might wish to design is, eo ipso, faulty. An understanding of 'the first order' is, I would almost say by definition, impossible for the world of atoms"
— Werner Heisenberg
Philosophic Problems of Nuclear Science, trans. F. C. Hayes (1952), 38.
If the the repulsive force between 2 protons,is mediated by the creation and exchange of virtual particles,and this field of virtual particles is the barrier,then you have just as much uncertainty about the position and strength of the barrier,as you do about the position and momentum of the protons.
Can you show where in the various tunneling phenomena experiments, say the SIN tunneling spectroscopy using superconductors, that this barrier uncertainty manifests its effect?
Zz.
One of my favorite quotes deals with the difficulty in understanding this.
Freeman Dyson: "Thirty-one years ago, Dick Feynman
told me about his "sum-over-histories" version of quantum
mechanics. "The electron does anything it likes", he said, "it goes
in any direction at any speed, forward or backward-in-time,
however it likes, and then you add-up the amplitudes and it gives
you the wave function." I said to him, "Your crazy". But he
wasn't."
The way I look at it, we have only a vague idea of what the "particle" is doing when we are not observing it. There is no particular reason to believe that it moves ballistically, or that it even traces a continuous path in space. I'm inclined to think that it doesn't.
derek101 said:
Drakkith
The interior of the sun is a good vacuum on the scale of nuclei: You just have to consider the two protons and nothing else.
There is a pep process (2 protons and one electron fuse), but that is rare.
We have a good idea what the wavefunction does, however.
so 2 protons in the vacuum of space can fuse,and form helium nuclei?
They can form deuterium (+positron+neutrino), as they do in the sun.
They need a significant relative velocity to have a reasonable fusion probability.
Related to What is the physics behind quantum tunneling
What is quantum tunneling?
Quantum tunneling is a phenomenon in quantum mechanics where a particle can pass through a potential barrier even though it does not have enough energy to overcome it. This is possible due to the probabilistic nature of particles at the quantum level.
How does quantum tunneling occur?
In quantum tunneling, a particle can pass through a potential barrier by "borrowing" energy from the barrier itself, resulting in a small probability of the particle appearing on the other side of the barrier. This is due to the wave-like behavior of particles at the quantum level.
What factors affect the probability of quantum tunneling?
The probability of quantum tunneling depends on several factors, including the thickness and height of the potential barrier, the energy of the particle, and the shape of the potential barrier. It also depends on the mass of the particle and the strength of the force acting on it.
What are some real-world applications of quantum tunneling?
Quantum tunneling has several important applications, such as in electron microscopes, where it allows for the imaging of extremely small objects. It is also used in scanning tunneling microscopes, which can image individual atoms on a surface. Additionally, it is a crucial concept in the development of new technologies such as quantum computing and tunnel diodes.
What are the implications of quantum tunneling in the field of physics?
Quantum tunneling plays a significant role in understanding the behavior of particles at the quantum level and has implications in various fields of physics, including quantum mechanics, solid-state physics, and nuclear physics. It challenges our classical understanding of the behavior of particles and has opened up new avenues of research in the field of quantum physics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
