MHB What is the positive integer value of $n$ if $3^{n} + 81$ is a perfect square?
The discussion revolves around finding a positive integer value of \( n \) such that \( 3^n + 81 \) is a perfect square. Initial attempts show that for \( n \leq 4 \), the expression does not yield a perfect square. A transformation using \( n = k + 4 \) leads to the equation \( 3^k + 1 = x^2 \), suggesting a relationship between \( 3^k \) and two consecutive integers. Some participants argue that \( 3^n + 81 \) cannot be a perfect square due to parity issues, while others counter that an odd \( n \) could yield a solution. The conversation highlights the complexity of the problem and the need for further exploration to determine valid values of \( n \).
juantheron
If $3^{n} +81$ is a perfect square, find a positive integer value of $n$.
My Trail:: When $n\leq 4,$ then easy to know that $3^{n} +81$ is not a perfect square.
Now let $\displaystyle n = k +4 (k\in \mathbb{Z^{+}}),$ then $3^{N} +81 = 81 (3^{k} +1).$
So $3^{N} +81$ is a perfect square, and $81$ is square,
there must be a positive integer $x,$ such that
$3^{k}+1 = x^2\Rightarrow 3^k = (x-1)\cdot (x+1)$
Now How can i solve after that
Help me
Thanks
Mathematics news on Phys.org
I would write:
$$3^n+81=m^2$$
$$3^n=(m+9)(m-9)$$
Now, observing that:
$$18+9=27=3^3$$ and $$18-9=9=3^2$$
What value do we obtain for $n$?
Hello.
3^n+81, It cannot be a perfect square, For being, both, odd numbers.
Demostration:
(2n-1)^2+(2m-1)^2=4(n^2+m^2)-4(n+m)+2=
=2[2(n^2+m^2)-2(n+m)+1]
The square root, of the latter expression, has to be an irrational number, for being divisible, only once for "2".
Regards.
mente oscura said:
$3^n+81$, It cannot be a perfect square
False. I can find a precise value $n$ for which the above is a perfect square.
Hint : Prove that $18$ is divisible by $m - 9$.
Hello.
I am sorry. Really, I have considered "n", even number and, it is not possible, but yes it can be an odd number.
Regards.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
