What is the power output of the heat engine?
In summary, the conversation discusses the use of a heat engine with a hot reservoir of steam at 100°C and a cold reservoir of ice at 0°C. After 1.3 hours of operation, 11 kg of steam condenses and 52 kg of ice melts. The equation W=Qin-Qout is suggested as the correct one for power output, but the participants are unsure how to find Qin or Qout from the given information. The suggestion to look up latent heats, which indicate the amount of heat needed for phase changes, is given to help solve the problem.
dragon162
The hot reservoir of a heat engine is steam at 100^ C while the cold reservoir is ice at 0 C. In 1.3 hr of operation, 11 kg of steam condenses and 52 kg of ice melts.
I think power output is W=Qin-Qout
I believe the equation i provided is the correct one for power output but i don't know how to find Qin or Qout from the information given. So any help would be appreciated.
Look up latent heats. They tell you how much heat is required to melt/freeze or condense/evaporate a substance.
Related to What is the power output of the heat engine?
The power output of a heat engine refers to the amount of energy that is generated by the engine per unit of time. It is usually measured in watts (W) or horsepower (hp).
How is the power output of a heat engine calculated?
The power output of a heat engine can be calculated using the formula P = Q/t, where P is the power, Q is the amount of heat transferred, and t is the time taken for the heat transfer to occur. This formula is derived from the first law of thermodynamics.
What factors affect the power output of a heat engine?
The power output of a heat engine can be affected by several factors, including the efficiency of the engine, the temperature difference between the hot and cold reservoirs, the type of working fluid used, and the design and size of the engine.
How does the power output of a heat engine compare to its efficiency?
The power output and efficiency of a heat engine are closely related. Generally, an engine with a higher power output will have a lower efficiency, and vice versa. This is because some of the energy produced by the engine is lost as heat and other forms of energy.
What are some real-world examples of heat engines and their power outputs?
Some common examples of heat engines include car engines, steam turbines, and gas turbines. Their power outputs can vary greatly depending on their specific design and purpose. For example, a car engine may have a power output of 100 horsepower, while a large gas turbine used for electricity generation may have a power output of several megawatts.
