MHB What Is the Probability Distribution for Drawing Spades Without Replacement?
The discussion focuses on calculating the probability distribution for drawing spades from a deck of cards without replacement. The initial poster presents their calculations for the probabilities of drawing spades on successive draws, using conditional probabilities. Other participants clarify that the question likely seeks the probabilities of drawing 0, 1, 2, or 3 spades, suggesting the use of the hyper-geometric distribution. They provide specific calculations for these probabilities and emphasize the importance of ensuring that the total probabilities sum to one. The conversation highlights the need for clear interpretation and accurate calculations in probability problems.
Roohul Amin
Dear All sorry for repeated post;
There is a problem
Problem: Three cards are drawn in succession from a deck without replacement. find the probability distribution for the number of spades.
I have come with this solution.
Let S1: appearance of spade on first draw S2: appearance of spade on 2nd draw S3: appearance of spade on 3rd draw
S01: No spade on 1st draw S02: No spade on 2nd draw
P(S1)=13/52
P(S2)=P(S2/S1)+P(S2/S0)=12/51+13/51
P(S3)=P(S3/S01*S02)+P(S3/S1*S02)+P(S3/S1*S2)=13/50+12/50+11/50
Need your opinion Please!
Mathematics news on Phys.org
Hi there,
So a probability distribution is a function of some kind of input parameter(s). Are you asking what is the probability of drawing three spades or trying to generalize the distribution in terms of the three draws?
In either case the final result would be a multiplication, not a sum. I think you are in the right direction but some clarification on the question would be helpful.
If you want an exhaustive list of possible outcomes, the event is spade/no spade, so the total number of outcomes is $2^3=8$.
Thanks for your reply Jamson: it seems the hyper-geometric distribution fit well this situation, what do you think?
There is a problem
P(S1)=13/52
I am not entirely sure that I understand the question. But I think that it is asking for the probabilities for drawing 0, 1, 2 or 3 spades.
Let $P(n)$ denote the probability of drawing $n$ spades. Then $P(0) = \dfrac{39 \cdot 38 \cdot 37}{52 \cdot 51 \cdot 50} \approx 0.4135$.
For $P(1)$ we have to draw one spade and two non-spades. There are three possibilities, since the one spade could be either the first, the second or the third card drawn. So $P(1) = \dfrac{3 \cdot 39 \cdot 38 \cdot 13}{52 \cdot 51 \cdot 50} \approx 0.4359.$
In a similar way, you can calculate $P(2)$ and $P(3)$.
If I am interpreting the question correctly, you answer should be the set of four probabilities $P(0),\ldots,P(3)$. As a check, you should verify that your four probabilities add up to $1$.
in the denominator the values are clearly 52C3. But the values in numerator i.e 3.52.52.39 are making some confusion to me, would you pleas give details. Thanks
Sorry, my mistake. I should have written 3.39.38.13 there (I have now corrected it). The idea is that if you want just one of the three cards to be a spade, then you have 39 choices for the first non-spade, 38 for the second non-spade, and 13 for the spade. The 3 (as I mentioned in my previous comment) comes from the fact that the spade could be either the first, the second, or the third card to be chosen.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
