MHB What is the Probability of a Tetrahedron Landing on a Specific Colored Side?
  • Thread starter Thread starter mathmari
    Tetrahedron
The discussion focuses on the probability of a tetrahedron landing on specific colored sides: red, blue, or green, with one side painted in all three colors. It establishes a probability space with the outcome set containing the colors and the fourth side, leading to probabilities of P(A) = P(B) = P(C) = 1/2 for each event. The analysis shows that while any two events among A, B, and C are independent, the three events together are not independent due to the intersection probabilities. The conclusion confirms the calculations and reasoning regarding the independence of these events.
mathmari
MHB
Hey! 😊
Let one of the four sides of a tetrahedron be red, one blue, one green and the fourth side painted with all three colours. We consider the following events :
A: = The tetrahedron falls on a side with red colour.
B: = The tetrahedron falls on a side with a blue colour.
C: = The tetrahedron falls on a side with a green colour
Give a suitable probability space and give the events A, B and C as subsets of the result set.
(a) Show that two of the events A, B and C are independent.
(b) Are A, B, C independent? Explain. Does it hold that $P(A)=P(B)=P(C)=\frac{2}{4}$ because there is one side for each colour the the 4th side contains also each colour?
The probability space is the set of colours, or not?
:unsure:
Hey mathmari!
I believe the probabilities are indeed $\frac 24$ each. (Nod)
A probability space is supposed to be a triplet of a sample space, an event space, and a probability function.
You only mentioned the sample space. (Worried)
Either way, I think that the outcome space must contain each of the sides. We only have 3 colors but 4 sides... (Worried)
We could pick for instance $\Omega=\{red,green,blue,all\}$. 🤔
So the probability space consists of the outcome space $\Omega=\{red,green,blue,all\}$ and each outcome has the same probability $\frac{2}{4}=\frac{1}{2}$, right? :unsure:
We have that \begin{align*}&A = \{red, \ all\}\subseteq \Omega \\ &B = \{blue, \ all\}\subseteq \Omega\\ &C = \{green, \ all\}\subseteq \Omega\end{align*}
(a) We have that $A\cap B = A\cap C=B\cap C=\{all\}$ so we get that \begin{align*}&P(A)=\frac{1}{2} \\ &P(B)=\frac{1}{2} \\ &P(C)=\frac{1}{2} \\ &P(A\cap B) = \frac{1}{4} \\ &P(A\cap C)= \frac{1}{4} \\ &P(B\cap C)= \frac{1}{4} \\ & \Rightarrow P(A)\cdot P(B)=\frac{1}{2}\cdot \frac{1}{2}=\frac{1}{4}=P(A\cap B) \\ & \Rightarrow P(A)\cdot P(C)=\frac{1}{2}\cdot \frac{1}{2}=\frac{1}{4}=P(A\cap C) \\ & \Rightarrow P(B)\cdot P(C)=\frac{1}{2}\cdot \frac{1}{2}=\frac{1}{4}=P(B\cap C)\end{align*} That means that each two of the events $A$, $B$ and $C$ are independent. (b) We have that $A\cap B \cap C=\{all\}$ so we get that \begin{align*}&P(A)=\frac{1}{2} \\ &P(B)=\frac{1}{2} \\ &P(C)=\frac{1}{2} \\ &P(A\cap B\cap C) = \frac{1}{4} \\ & \Rightarrow P(A)\cdot P(B)\cdot P(C)=\frac{1}{2}\cdot \frac{1}{2}\cdot \frac{1}{2}=\frac{1}{8}\neq \frac{1}{4}=P(A\cap B\cap C) \end{align*} That means that the events $A$, $B$ and $C$ are not independent. Is everything correct and complete? :unsure:
All correct and complete. (Sun)
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
