MHB What is the Probability of Getting an Even Number of Heads with an Unfair Coin?
  • Thread starter Thread starter veronica1999
The discussion focuses on calculating the probability of obtaining an even number of heads when tossing an unfair coin with a 2/3 chance of heads, over 50 tosses. The binomial probability formula is applied, leading to the conclusion that the probability of getting an even number of heads is approximately 0.5. The participants explore various mathematical approaches, including the use of the binomial theorem and complementation rule, to derive the formula for the probability. Ultimately, the probability is expressed as P(X) = 1/2(1 + 1/3^50), indicating it is slightly greater than 1/2 due to the nature of the coin. The problem is recognized as interesting and prompts further generalization for different probabilities.
veronica1999
An "unfair" coin has a 2/3 probability of turning up heads. If this coin is tossed 50 times, what is the probability that the total number of heads is even?
I set up an equation but I am having trouble with the calculation.
50C0 X (2/3)^0 X (1/3)^50 + 50C2 X (2/3)^2 X (1/3)^48 +... 50C50 (2/3)^50X(1/3)^0
I tried splitting it up thinking of the sigma notation.
(2/3)^0 + (2/3)^2 .....+ (2/3)^50 = { 1- (4/9)^25} / (1- 4/9) (1/3)^0 ..... + (1/3)^50 = { 1- (1/9)^25}/ (1-1/9)
It doesn't seem to work...:confused:
Mathematics news on Phys.org
Re: coins
As you have realized, we need the binomial probability formula:
$\displaystyle P(x)={n \choose x}p^x(1-p)^{n-x}$
Identifying:
$\displaystyle n=50$
$\displaystyle p=\frac{2}{3}$
we then need to compute:
$\displaystyle P(X)=\sum_{k=0}^{25}P(2k)=\sum_{k=0}^{25}\left[{50 \choose 2k}\left(\frac{2}{3} \right)^{2k}\left(\frac{1}{3} \right)^{50-2k} \right]$
Relying on technology, we find:
$\displaystyle P(X)=\frac{358948993845926294385125}{717897987691852588770249}\approx0.5$
Can you think of a way to obtain the approximation from the binomial theorem and the complementation rule?
Re: coins
Identifying:
There is i/2 and 1/2( 1+ 1/3^50) in the answer choices. Which one would be the answer?
i am trying to work backwards from the answer.
oops, i see the second one is the answer :o
Re: coins
I see we aren't meant to either use technology, or use an approximation.
Intuition tells us that since there are 26 favorable outcomes and 25 unfavorable that the probability will be slightly greater than 1/2. But how much greater?
Perhaps if we rewrite the sum:
$\displaystyle P(X)=\frac{1}{3^{50}}\sum_{k=0}^{25}\left[{50 \choose 2k}2^{2k} \right]$
Now, let's let Y be the event of getting an odd number of heads, and write:
$\displaystyle P(X)-P(Y)=\delta$
$\displaystyle \frac{1}{3^{50}}\sum_{k=0}^{25}\left[{50 \choose 2k}2^{2k} \right]-\frac{1}{3^{50}}\sum_{k=0}^{24}\left[{50 \choose 2k+1}2^{2k+1} \right]=\delta$
$\displaystyle 3^{50}\delta=\sum_{k=0}^{50}\left[{50 \choose k}2^{k}(-1)^{50-k}\right]$
By the binomial theorem, we have:
$\displaystyle 3^{50}\delta=(2-1)^{50}=1$
and so:
$\displaystyle \delta=\frac{1}{3^{50}}$
Hence:
$\displaystyle P(X)-P(Y)=\frac{1}{3^{50}}$
$\displaystyle P(X)+P(Y)=1$
Adding, we find:
$\displaystyle 2P(X)=1+\frac{1}{3^{50}}$
and so finally, we have:
$\displaystyle P(X)=\frac{1}{2}\left(1+\frac{1}{3^{50}} \right)$
Re: coins
and so:
Hence:
Adding, we find:
Thanks!
Now it is absolutely clear.:D
I found this problem quite interesting and thought about it while I was out and so wanted to generalize a bit and cut out some of the unnecessary hand-waving...
Let's say the probability of getting a heads is $\displaystyle p$ and we flip the coin $\displaystyle 2n$ times where $\displaystyle n\in\mathbb{N}$. What is the probability that the total number of heads is even?
Let $\displaystyle P(X)$ be the probability that the total number of heads is even and $\displaystyle P(Y)$ be the probability that the total number of heads is odd.
$\displaystyle P(X)-P(Y)=\sum_{k=0}^{2n}\left[{2n \choose k}p^{2n-k}(p-1)^k \right]=(2p-1)^{2n}$
Adding, we find:
$\displaystyle 2P(X)=1+(2p-1)^{2n}$
$\displaystyle P(X)=\frac{1}{2}\left(1+(2p-1)^{2n} \right)$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
