MHB What Is the Probability of Guessing Correctly on a Multiple Choice Test?
The discussion focuses on calculating the probability of guessing correctly on a multiple-choice test and understanding the differences between binomial and hypergeometric distributions. The probability of getting exactly 6 out of 10 questions correct, when guessing, is calculated using the formula $$\binom{10}{6} (0.2)^6 (0.8)^4$$. A related question about selecting all-stars from a group leads to confusion about whether to multiply by the combination formula twice, which is clarified by noting that order does not matter in these cases. The conversation emphasizes the importance of understanding the definitions and applications of probability distributions. Overall, the participants aim to clarify the correct approach to solving these probability problems.
Amad27
A test consists of 10 multiple choice questions with five choices for each question. As an experiment, you GUESS on each and every answer without even reading the questions.
What is the probability of getting exactly 6 questions correct on this test?
The answer is: $$\binom{10}{6} (0.2)^6 (0.8)^4$$
I see that, there $\binom{10}{6}$ ways of selecting $6$ correct questions here.
But then, take a question like:At a soccer match there are 230 all-stars and 220 half-stars. You pick five people from the crowd. What is the probability that exactly two are all-stars?
I would say:
$$P = \frac{\binom{230}{2} \cdot \binom{220}{3}}{\binom{450}{5}}$$
My question is, arent there also many ways to choose the $2$ all stars out of the $230$? So wouldn't you multiply by $\binom{230}{2}$ again?
Mathematics news on Phys.org
Hi Olok,
I'm not sure I understand your question.
$\binom{230}{2}$ is the number of ways to choose the $2$ all stars out of the $230$, which is a pretty large number.
What is the reason you think we should multiply by it twice?
Btw, your second formula represents the hypergeometric distribution instead of the binomial distribution. (Nerd)
I like Serena said:
Hi Olok,
No, because in the first one, we multiply by $\binom{n}{k}$ because the order matters, doesn't the order also matter in the second one?
I think I am messing this all up.
Are you using these definitions to solve probability like this? Like the definition of hypergeometric distribution, binomial distribution? Is it by definition that we use that?
Whether order matters or not can be a bit confusing.
Actually, in both of these cases, we say that order does not matter.
For instance in the first case, it doesn't matter which of the questions are right, only how many of them.
Now suppose we want to know the probability that exactly the first 6 questions are right and the last 4 questions are wrong.
Then the order does matter and the probability is $0.2^6 \cdot 0.8^4$.
But since the order does not matter, the probability goes up by $\binom{10}{6}$, since that is the number of different configurations to have 6 questions right.
The relevant definition, if we want to call it that, is that
$$P(\text{Desirable outcome}) = \frac{\text{Number of desirable outcomes}}{\text{Total number of outcomes}}$$
(Fine print: that is under the assumption that all outcomes are equally likely.)
The formulas are derived from that. Once you have them, it's easiest to use them rather than derive them again.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
