NOSYLA
- 1
Recently the James Webb Telescope discovered an exoplanet 99% the size of Earth. Its name is LHS 475 b. What is the probability that there is life on this planet?
You mean the probability of 1% probability is greater than the probability of 99% probability?phinds said:Somewhere between 0% and 100%, but likely very close to the zero end.
By quite a bit, I imagine.PeroK said:You mean the probability of 1% probability is greater than the probability of 99% probability?
You mean there's a high probability that the probability of 1% probability is greater than the probability of 99% probability?phinds said:By quite a bit, I imagine.
Probably.PeroK said:You mean there's a high probability that the probability of 1% probability is greater than the probability of 99% probability?
Since you didn't supply a link to the information, and I'm too lazy to go searching for it right now, did the article say if the planet is likely in the Goldilocks Zone of its star?NOSYLA said:Recently the James Webb Telescope discovered an exoplanet 99% the size of Earth. Its name is LHS 475 b. What is the probability that there is life on this planet?
That's a very good point, but I'm still not sure that it is enough to answer the question.berkeman said:Since you didn't supply a link to the information, and I'm too lazy to go searching for it right now, did the article say if the planet is likely in the Goldilocks Zone of its star?
True, but if it's not in the GZ, that would preclude most forms of life that we have experience with...FactChecker said:I'm still not sure that it is enough to answer the question.
The researchers have also confirmed that LHS 475 b maintains a tidal-locked orbit with its star of just two days — far too close to attempt with Sol but, because LHS circles a red dwarf that's producing less than half of our sun's energy, can theoretically maintain an atmosphere.
Huh. I read that and the first thing I thought of was that the planet must have spent too much time in the bathtub.berkeman said:Hmm, tidally locked and one side is too hot and one side is too cold. Kind of re-defines the meaning of the Goldilocks Zone (into a ring around the planet)...
What is the orbital period and predicted surface temperature of that planet ?NOSYLA said:Recently the James Webb Telescope discovered an exoplanet 99% the size of Earth.
No - make it worse.Vanadium 50 said:While I agree an exact numerical probability is meaningless, the probability is very very low.
- No detected atmoshere
- Too hot
- Likely tidally locked (maybe a 3:2 would improve this)
As of now, LHS475b is an exoplanet about which we still have limited information. The habitability of this planet depends on various factors such as atmospheric composition, surface temperature, and the presence of liquid water. Current data does not provide enough detail to conclusively determine its habitability.
The key factors include the planet's distance from its star (which affects its temperature), the presence and composition of an atmosphere, geological activity, magnetic field strength, and the availability of liquid water. These factors collectively determine whether the conditions on LHS475b could support life as we know it.
LHS 475 is a red dwarf star, which can have significant implications for the planet's habitability. Red dwarfs are known for their long lifespans but also for their potential to emit strong stellar flares. These flares can strip away a planet's atmosphere, making it difficult for life to develop or be sustained. However, if LHS475b has a strong magnetic field and a stable atmosphere, it might still be capable of supporting life.
Scientists use a variety of methods to detect signs of life on exoplanets. These include analyzing the planet's atmosphere for biosignatures (such as oxygen, methane, and other organic molecules), studying its surface conditions through direct imaging, and observing the planet's interaction with its star. Spectroscopy is a key tool in these investigations, allowing researchers to determine the chemical composition of the planet's atmosphere.
No, there has been no evidence of life found on LHS475b so far. The search for life on exoplanets is a complex and ongoing process, requiring advanced technology and detailed observations. While LHS475b remains an interesting candidate for further study, no direct signs of life have been detected at this time.
