What Is the Probability That a Chord on a Unit Circle Is At Least 1 Unit Long?
  • MHB
  • Thread starter anemone
In summary, the probability of a randomly chosen chord on a unit circle having a length less than 1 is approximately 0.7854 or 78.54%. This probability is calculated by dividing the length of the chord by the diameter of the circle. The probability of a unit circle chord length cannot be greater than 1 as the length of a chord cannot be greater than the diameter of the circle. The position of the chord on the circle does not affect the probability of its length as all chords on a unit circle have an equal chance of being chosen. The only factor that can affect the probability of a unit circle chord length is the length of the chord itself, as the length of a chord increases, the probability of it being chosen
anemone
MHB
POTW Director
3,883
115
Two points are picked at random on the unit circle $x^2+y^2=1$. Determine the probability that the chord joining the two points has length at least 1.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Hello MHB Community,
anemone couldn't be with us this week, but she conscientiously made provisions for me to post this week's POTW for Secondary School/High School Students in her stead.
So, with no further ado...
Congratulations to the following members for their correct solutions::)
  1. MarkFL
  2. magneto
  3. laura123
  4. Ifdahl
Honorable mention goes also to chisigma as he simply misread the problem and computed the probability that the given chord is no greater than one unit in length.
Solution from magneto:
Consider a circle $O$ with radius $r = 1$. Let a point $A$ on the circumference be given.
Then there are two distinct points on the circumference $B$ and $B'$ where $AB = 1 = AB'$.
Note that $\triangle AOB$ and $\triangle AOB'$ are both equilateral, so $m \measuredangle BAB' = 120^\circ$,
and the major arc $BB'$ is $240^\circ$. If any point $C$ lies on the major arc $BB'$, the length of chord $AC \geq 1$.
So, the probability is $\frac{240}{360} = \frac 23$.
Solution from Ifdahl:
Two points picked at random on the unit circle spans an arc of length $\alpha$, where $0 \le \alpha \le \pi$. Thus picking two points at random corresponds to choosing a certain $\alpha$ - just like cutting out a piece of a circular birthday cake :). The pdf for a random choice of $\alpha$ is uniform continuous, because every possible $\alpha$-value has the same weight*. If the chord, that connects the points has length $c = 1$, we have the limit: $\alpha = \frac{\pi}{3}$. (Cf. attached figure).
Thus
$P(\alpha \le \frac{\pi}{3}) = P(c \le 1) = \frac{\frac{\pi}{3}-0}{\pi – 0}=\frac{1}{3}$
- and therefore the probability of choosing two points at random with a corresponding chord of length greater than $1$ is:
$ P(\alpha > \frac{\pi}{3}) = P(c > 1) = 1 - \frac{1}{3}= \frac{2}{3}$.
(*).This is not the case for the distribution of the cord length, $c$.
FAQ: What Is the Probability That a Chord on a Unit Circle Is At Least 1 Unit Long?
1. What is the probability of a randomly chosen chord on a unit circle having a length less than 1?
The probability of a randomly chosen chord on a unit circle having a length less than 1 is approximately 0.7854 or 78.54%.
2. How is the probability of a chord length calculated on a unit circle?
The probability of a chord length on a unit circle is calculated by dividing the length of the chord by the diameter of the circle.
3. Can the probability of a unit circle chord length be greater than 1?
No, the probability of a unit circle chord length cannot be greater than 1 as the length of a chord cannot be greater than the diameter of the circle.
4. Is the probability of a unit circle chord length affected by the position of the chord on the circle?
No, the position of the chord on the circle does not affect the probability of its length as all chords on a unit circle have an equal chance of being chosen.
5. What other factors can affect the probability of a unit circle chord length?
The only factor that can affect the probability of a unit circle chord length is the length of the chord itself. As the length of a chord increases, the probability of it being chosen decreases.
