MHB What is the probability that exactly 8 of them are over the age of 65
  • Thread starter Thread starter Crowbarr
    Age Probability
The discussion focuses on calculating probabilities using the binomial distribution for coronary bypass patients, specifically regarding the age of patients over 65. It cites that 53% of coronary bypass surgery patients were over 65 in 2008 and involves a sample of 15 patients. The calculations for various scenarios, such as exactly 8 patients over 65 and probabilities for fewer or more than 10, are explained using the binomial formula. The thread also questions the participants' understanding of probability concepts, suggesting they should attempt to solve the problems independently. Overall, the emphasis is on applying binomial distribution principles to derive the required probabilities.
Crowbarr
2) The Agency for Healthcare Research and Quality reported that 53% of people who had coronary bypass surgery in 2008 were over the age of 65. Fifteen coronary bypass patients are sampled.
a) What is the probability that exactly 8 of them are over the age of 65?
b) P (less than 10 are over 65) =
c) P (more than 10 are over 65) =
d) P (11 or fewer are over 65) =
e) P ( more than 11 are over 65) =
Mathematics news on Phys.org
I am puzzled by this thread. If you have never taken a course in "probability and statistics" where did you get these exercises? If you have, or are now taking such a course, why have you shown no attempt to answer these yourself?
They are all applications of the basic "binomial distribution": if the probability a particular event will result in "a" is p and the probability it will result is "b" is 1- p, the probability that, in n events, it will result in "a" i times and "b" n-i times with probability [math]\begin{pmatrix}n \\ I \end{pmatrix}p^i(1- p)^{n-I}[/math].
Here, "a" is "a person who had coronary bypass surgery is over 65", p= 0.53, "b" is "a person who had coronary bypass surgery is NOT over 65", and 1- p= 1- 0.53= 0.47. n= 15. [math\begin{pmatrix} n \\ i\/end{pmatrix}[/math] is the "binomial coefficient", [math]\frac{n!}{i!(n-i)!}[/math].
In problem (a) i= 8.
in problem (b) it is simplest to calculate that for i= 10, 11, 12, 13, 14, and 15, add them (to determine the probability "10 or more are over 65") and subtract from 1. The harder way is to calculate that for i= 0, 1, 2, 3, 4, 5, 6, 7, 8, and 9 and add.
In problem (c) you can use the number you got before you subtracted from 1!
In problem (d) "11 or fewer" is the same as "less than 12" so you can do the same as (c), calculate the probability for i= 12, 13, 14, 15 and subtract from 1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
