What is the probability that the ball was labeled
In summary, the conversation discusses the probability of selecting a labeled frosted ball from a tank containing 50 balls, as well as the probabilities of selecting a frosted ball followed by a mild ball, and two consecutive frosted balls without replacement. The probabilities for these scenarios are calculated based on the number of frosted and labeled balls in the tank.
Jason000000
A tank contains 50 balls. 10 are frosted (F) and labeled (L), 23 are mild (M) and unlabeled, 7 are frosted and not labelled (N), 10 are mild and labeled.
1. A ball is randomly selected from the tank and it was frosted. What is the probability that the ball was labeled?
2. The 1st ball was frosted and the 2nd one was mild (not frosted) What is the probability if we would do two trials?
3. To select a ball was frosted and this ball was not returned to the tank, and select the 2nd one frosted again. What is the probability?
Mathematics news on Phys.org
I finally figured it out .. but I would appreciate if anyone can confirm the answers .. thanx
for Q1. P(L|F) = 10/17
for Q2. P(F) x P(M) = 17/50 x 33/50 = 0.34 x 0.66 = 0.2244
for Q3. P(F1) = 17/50 & P(F2) = 16/49
P(F1|F2) = 17/50 x 16/49 = 0.34 x 0.326 = 0.111
The ball is one of the 17 frosted balls of which 10 are labeled. The probability this frosted ball is labeled is 10/17.
What is the probability of what? Are you asking "if we take two balls what is the probability that the first is frosted and the second is not"? If so then is the first ball returned to the tank or not?
There are initially 50 balls, 17 of which are frosted. The probability the first ball selected is frosted is 17/50. If that ball is not returned to the tank, there are then 49 balls, 33 of which are not frosted. The probability that the second ball selected is not frosted is 33/49. In this situation the probability the first ball is frosted and the second ball is not is (17/50)(33/49). If the first ball is returned to the tank, the probability second ball is not frosted is (33/50) so the probability of "frosted, not frosted", in that order, is (17/50)(33/50).
Initially there are 50 balls in the tank, 17 of which are frosted. The probability the first ball is frosted is 17/50. Since that ball is not returned there are 49 balls, 16 of which are frosted. The probability the second ball is also frosted is 16/49. The probability of two frosted balls, without replacement, is (17/50)(16/49).
Country Boy said:
The ball is one of the 17 frosted balls of which 10 are labeled. The probability this frosted ball is labeled is 10/17.What is the probability of what? Are you asking "if we take two balls what is the probability that the first is frosted and the second is not"? If so then is the first ball returned to the tank or not?
There are initially 50 balls, 17 of which are frosted. The probability the first ball selected is frosted is 17/50. If that ball is not returned to the tank, there are then 49 balls, 33 of which are not frosted. The probability that the second ball selected is not frosted is 33/49. In this situation the probability the first ball is frosted and the second ball is not is (17/50)(33/49). If the first ball is returned to the tank, the probability second ball is not frosted is (33/50) so the probability of "frosted, not frosted", in that order, is (17/50)(33/50).Initially there are 50 balls in the tank, 17 of which are frosted. The probability the first ball is frosted is 17/50. Since that ball is not returned there are 49 balls, 16 of which are frosted. The probability the second ball is also frosted is 16/49. The probability of two frosted balls, without replacement, is (17/50)(16/49).
can u confirm above the answers I provided before your reply? many thanx!
Why are you asking CBoy that? His answers are SAME as yours!
because I have extra to his answer:-
is it correct to multiply and get these results?
Depends on what your teacher expects.
Usually shown as single fraction: 561/2500 and 136/1225.
FAQ: What is the probability that the ball was labeled
The probability that the ball was labeled depends on several factors, such as the number of unlabeled balls and the total number of balls in the sample. Without further information, it is impossible to determine the exact probability.
How do you calculate the probability of a labeled ball?
To calculate the probability of a labeled ball, you need to know the total number of balls in the sample and the number of labeled balls. The probability can be calculated by dividing the number of labeled balls by the total number of balls.
Is the probability of a labeled ball the same as the probability of an unlabeled ball?
No, the probability of a labeled ball is not necessarily the same as the probability of an unlabeled ball. This is because the number of labeled and unlabeled balls in the sample may be different.
What is the difference between probability and possibility?
Probability is a mathematical concept that refers to the likelihood of an event occurring. Possibility, on the other hand, refers to the chance that something could happen, regardless of its likelihood.
Can the probability of a labeled ball change over time?
Yes, the probability of a labeled ball can change over time if the number of labeled and unlabeled balls in the sample changes. It can also change if new information is obtained that affects the probability calculation.
