What is the proof for this polynomial inequality problem?
In summary: P(2)>3^n$$ \therefore P(2)\geq 3^n$In summary, we want to prove that for a polynomial with non-negative coefficients and \(n\) real roots, \(P(2)\ge 3^n\). Using the AM-GM inequality, we can show that \(P(2)\ge (2+1)^n=3^n\). This result can be generalized to any positive integer \(k\), where \(P(k)\ge (k+1)^n\). We can also consider specific cases, such as when all the coefficients are 1, in which case \(P(2)=(2+1)^n=3^n\) and
CaptainBlack
807
I may have posted this back in the Old Country, but:
let the polynomial: \[P(x)=x^n+a_1X^{n-1}+ ... + a_{n-1}x+1 \] have non-negative coeficients and \(n\) real roots.
Prove that \(P(2)\ge 3^n \)
CB
Mathematics news on Phys.org
A hint would be appreciated.
I think $3^n=(2+1)^n=\sum_{k=0}^n\dbinom{n}{k}2^k$ will be used somewhere.
Will do when I am at home with my notes, but to get you started the non-negativity of the coefficients tell you that there are no positive roots (there is a supprise, CaptainBlack uses Descartes rule of signs). And that there are \(n\) real roots means that:
\[ P(x)=\prod_{i=1}^n(x+a_i),\ \ \ a_i>0 \]
and:
\[ \prod_{i=1}^n a_i=1 \]
CB
And the only other idea involved is the AM-GM inequality
CB
I've sort of a set-up so far. I'm trying to work backwards but I think I'm missing a step.
$\displaystyle 3^n = \bigg[2+\prod_{1 \le k \le n}a_{k}\bigg]^n \le \bigg[2+\bigg(\prod_{1 \le k \le n}a_{k}\bigg)^{\frac{1}{n}}\bigg]^n \le \bigg[2+\frac{1}{n}\sum_{1 \le k \le n}a_{k}\bigg]^n = \bigg[\frac{1}{n}\sum_{1 \le k \le n}(2+a_{k})\bigg]^{n} \ge \prod_{k=1}^{n}(2+a_{k}) = P(2).$
Is there a missing inequality here that fixes this? I'm really no good with inequalities! (Giggle)
---------- Post added at 03:17 AM ---------- Previous post was at 03:13 AM ----------
I've tried that (by creating a double sum, although I've no idea why) but to no avail unfortunately.
Use the AM-GM inequality on each factor of \(P(2)\):
$$ 2+a_i=1+1+a_i \ge 3(1\times 1\times a_i)^{1/3} $$
CB
CB
Which of course tells us that the more general result holds:
For any positive integer \(k\) we have \( P(k)\ge (k+1)^n \)
CB
Let P(x)=(x+b1)(x+b2)(x+b3)------------(x+bn)
if bi=1 (i=1,2,---------------n) then
$P(x)=(x+1)^n$
$ \therefore P(2)=(2+1)^n=3^n$
for some bi and bj (here bi and bj are not equal to 1 ,then bi and bj are
reciprocal to each other (again i,j=1,2,----n )
let bi=k (k>0) ,then bj=$\dfrac {1}{k}$
$ \therefore P(x)=(x+1)^{n-2}(x+k)(x+\dfrac {1}{k})$
$( \because 2k+\dfrac {2}{k}>4) $
$ \therefore P(2)=(2+1)^{n-2}(2+k)(2+\dfrac {1}{k})> 3^n$
FAQ: What is the proof for this polynomial inequality problem?
What is a polynomial inequality problem?
A polynomial inequality problem is a type of mathematical problem that involves finding the values of a variable that make a polynomial inequality true. It typically consists of a polynomial expression on one side of an inequality sign, and a constant or another polynomial expression on the other side.
How do I solve a polynomial inequality problem?
To solve a polynomial inequality problem, you must first isolate the variable on one side of the inequality sign. Then, you can use algebraic techniques such as factoring, the quadratic formula, or the method of intervals to find the values of the variable that satisfy the inequality.
What are the common mistakes to avoid when solving polynomial inequality problems?
One common mistake when solving polynomial inequality problems is forgetting to flip the direction of the inequality sign when multiplying or dividing by a negative number. Another mistake is not checking the solutions to make sure they satisfy the original inequality.
How do I graph a polynomial inequality?
To graph a polynomial inequality, you can first graph the corresponding polynomial equation. Then, you can use a test point to determine which side of the graph represents the solutions to the inequality. The solutions will be either all the points on or above the graph, or all the points on or below the graph, depending on the direction of the inequality sign.
How can I apply polynomial inequalities in real-life situations?
Polynomial inequalities can be applied in many real-life situations, such as finding the maximum or minimum values of a function, determining the range of possible values for a quantity, or solving optimization problems. They can also be used to analyze data and make predictions in fields such as economics, engineering, and science.
