What is the purpose by putting 2 ball valves together? And there is a
In summary, the purpose of having two block valves together is to isolate hazardous fluids so that maintenance can be performed safely, and there are other applications as well.
Ng Soon Hao
What is the purpose by putting 2 ball valves together? And there is a gate valve for sampling in between these 2 ball valves. any1 please provide me an explanation thxxx
What you're describing sounds like a "double block and bleed". Two valves are put in series on a piping run (block valves) with another valve off a T between them that runs to a vent (bleed valve).
One purpose is to isolate hazardous fluids so that maintenance can be performed safely. The procedure would have both block valves closed and the bleed valve open to vent during any maintenance. That way, if the one block valve leaks back toward where maintenance is being performed, it will go out the vent and you have a second block valve protecting you from this leakage.
I've also seen them being installed where the T has something in it such as a pressure gage or transducer that needs periodic calibration. The two block valves are closed to isolate the component and the bleed valve is used to apply pressure for calibrating the instrument.
Those are the two main reasons I've heard of but there could be others.
thx for your explanation, it is very helpful ! =)
Couple of additional applications include common drain or vent that allows either or both tanks to be drained/vented. Another is to provide redundant isolation capability and leakage detection.
FAQ: What is the purpose by putting 2 ball valves together? And there is a
What is the purpose of putting 2 ball valves together?
The purpose of putting 2 ball valves together is to create a more secure and reliable system for controlling the flow of a liquid or gas. By using two ball valves, you can ensure that there are no leaks or disruptions in the flow of the substance.
How do 2 ball valves work together?
When 2 ball valves are connected, they work in tandem to control the flow of a substance. One valve is used as the main shut-off valve, while the other is used as a backup or isolation valve. When the main valve is closed, the backup valve can be opened to allow for maintenance or repairs without disrupting the flow.
What are the benefits of using 2 ball valves instead of one?
Using 2 ball valves provides added security and reliability compared to using just one valve. If one valve fails or needs to be shut off for maintenance, the other valve can still control the flow. This can also prevent potential hazards or accidents from occurring.
How do 2 ball valves compare to other types of valves?
Compared to other types of valves, 2 ball valves are easier to maintain and have a longer lifespan. They also offer more precise control over the flow of substances and are less likely to leak. However, they may be more expensive and take up more space than other types of valves.
In what situations would 2 ball valves be used?
2 ball valves are commonly used in industrial settings, such as oil and gas pipelines, to control the flow of substances. They are also used in plumbing systems, water treatment plants, and other applications where precise control and reliability are important.
