What is the purpose of Electro-Optical Modulator (EOM)?
In summary, the purpose of the EOM in a distributed Brillouin sensor is to generate both the pump and probe waves from a single physical light source. This is necessary because direct modulation of a laser diode can increase phase noise, resulting in spectral broadening. To avoid this, an external modulator is used, such as a Mach-Zender interferometer, to encode information onto the optical carrier waveform. This is important for distributed Brillouin sensors, which require a source with a narrow linewidth to operate effectively.
OrangeYogi
Hello,
I'm studying the setup of distributed Brillouin sensor (using fibre optics) and don't quite understand the purpose of EOM in the sensor. It says that
"to generate both the pump and the probe waves from a single physical light source by using an electro-optical modulator (EOM)", but since we have a reflected fibre end, why do we have to generate two waves?
Thank you.
Direct modulation of a laser diode increases the phase noise of a laser output. The reason is that the number of carriers injected directly determines the number of stimulated photons and vice versa. The result is that the refractive index is also directly modulated leading to the cavity (from the photons perspective) to change in effective length. Hence at the laser output you would measure increased spectral broadening than is naturally present due to spontaneous emission.
One method to avoid this is to use an external modulator where the laser is operated in a continuous-wave (CW) mode and the beam itself is modulated. In fiber optics a Mach-Zender interferometer is usually used whereby the optical signal is split into two arms and one of the arms in directly modulated (electrically with a RF signal) and then the two beams are recombined. This will result in information to be encoded onto the optical carrier waveform.
I suspect, although I'm not familiar with distributed Brillouin sensors, that they require a source with a narrow linewidth to operate effectively.
Likes OrangeYogi
Related to What is the purpose of Electro-Optical Modulator (EOM)?
An Electro-Optical Modulator (EOM) is a device that is used to manipulate and control the properties of light. It works by changing the refractive index of a material in response to an applied electric field, allowing for the modulation of light waves passing through it.
How does an Electro-Optical Modulator (EOM) work?
An EOM typically consists of a crystal, such as lithium niobate or potassium titanyl phosphate, sandwiched between two electrodes. When an electric field is applied to the crystal, the refractive index of the material changes, causing a change in the speed of light passing through it. This change in speed can be used to manipulate the phase, amplitude, or polarization of the light wave.
What are the applications of Electro-Optical Modulators (EOMs)?
EOMs have a wide range of applications in various fields such as telecommunications, optical communication, laser technology, and imaging. They are used in devices like laser scanners, optical switches, and modulators for fiber-optic communication systems. They are also used in scientific experiments, such as in quantum optics and spectroscopy.
What are the advantages of using an Electro-Optical Modulator (EOM)?
One major advantage of EOMs is their fast response time, allowing for the modulation of light at high frequencies. They also offer high modulation depth and can handle high power levels. Additionally, EOMs are compact and can be easily integrated into optical systems, making them a versatile tool for manipulating light waves.
Are there any limitations of Electro-Optical Modulators (EOMs)?
While EOMs have many advantages, they also have some limitations. One limitation is that they are sensitive to temperature changes, which can affect their performance. EOMs also require a high voltage to operate, which can be a challenge in certain applications. Additionally, they can be expensive compared to other types of optical modulators.
  • Electrical Engineering
  • Atomic and Condensed Matter
