MHB What is the purpose of the MERGESORT algorithm?
  • Thread starter Thread starter evinda
    Algorithm
The MERGESORT algorithm recursively divides an array into two halves until each sub-array contains a single element. It then merges these sorted sub-arrays back together in a sorted manner using the MERGE function. The MERGE function creates temporary arrays for the left and right halves, compares their elements, and constructs a sorted array. An example demonstrates that given the array (3,5,2,7), the sorted output will be (2,3,5,7). Overall, MERGESORT efficiently sorts an array by leveraging the divide-and-conquer strategy.
evinda
MHB
Hello! (Mmm)
I am looking at the following algorithm:
Code:
MERGESORT(A,l,r){
   if (R==L) return;
   MERGESORT(A,l,floor((r+l)/2));
   MERGESORT(A,floor((r+l)/2)+1,r);
   return MERGE(A,l,r,floor((r+l)/2));
What does the above algorithm do? Could you explain it to me? (Thinking)
Technology news on Phys.org
evinda said:
Hello! (Mmm)
Code:
MERGESORT(A,l,r){
   if (R==L) return;
Hey! (Wave)
This merge-sort algorithm splits an array into 2 halves.
Then it "merge-sorts" each half.
The resultant array is "merged".
The same procedure is apply to any of those parts. (Nerd)
I like Serena said:
Hey! (Wave)
Could you give me an example, in order to apply the algorithm? (Wasntme)
Well, first you need the algorithm for MERGE.
Can you tell us what it is? (Wondering)
And then we should try to apply it to for instance (3,5,2,7)... (Thinking)
I can already tell you that (2,3,5,7) will come out! (Smile)
This is the algorithm [m] MERGE [/m] :
Code:
MERGE(A,p,q,r)
   n1=q-p+1
   n2=r-q;
   we create the arrays L[1 .. n1+1] and R[1 .. n2+1]
   for i=1 till n1
        L[i]=A[p+i-1]
   for j=1 till n2
        R[j]=A[q+j]
   L[n1+1]=oo
   R[n2+1]=oo
   i=1
   j=1
   for k=p till r
        if (L[i]<=R[j])
           then A[k]=L[i]
                  i=i+1
           else A[k]=R[j]
                 j=j+1
Before executing the command [m] return MERGE(A,l,r,floor((r+l)/2)); [/m], the following commands are executed:
[m] MERGESORT(A,0,1) [/m]
[m] MERGESORT(A,0,0) [/m]
[m] MERGESORT(A,2,3) [/m]
[m] MERGESORT(A,2,2) [/m]
[m] MERGESORT(A,3,3) [/m]Right? (Thinking)
What do we get from these calls? (Callme) (Thinking)
That's quite a complicated algorithm! (Sweating)
Well, it may suffice that it merges 2 sorted arrays into a new array, that is then sorted. (Whew)
Right? (Thinking)
Well, [m] MERGESORT(A,0,0) [/m] returns without doing anything.
Just like [m] MERGESORT(A,1,1) [/m], [m] MERGESORT(A,2,2) [/m], and [m] MERGESORT(A,3,3) [/m].
And after those, MERGE will be called. (Thinking)
What is then the function of [m] MERGESORT [/m] ? (Worried)
I haven't understood how we merge like that two sorted arrays? :confused:
Suppose we have the array L=(4,7,5,9,1,3,2,8).
Then first we sort L1=(4,7,5,9) and L2=(1,3,2,8).
Without going into the details, that will come out as S1=(4,5,7,9) respectively S2=(1,2,3,8).
Then we merge them while keeping the result sorted. (Thinking)
That is, we go through them entry by entry, each time selecting the smallest from both arrays.
First is 1 from S2, followed by 2 and 3 that also come from S2.
That gives us S=(1,2,3).
Then we continue with 4 from S1, so we get S=(1,2,3,4).
And we keep going until we have S=(1,2,3,4,5,7,8,9). (Nerd)
