What Is the Range of sec^4(x) + csc^4(x)?
  • MHB
  • Thread starter abender
  • Tags
    Range
In summary, the conversation is about finding the range of the expression \sec^4(x) + \csc^4(x). The solution involves rewriting the expression in terms of \tan(x) and \cot(x) and proving that it is always positive. The minimum value of the expression is found to be 8 and the range is determined to be [8, \infty). A simpler solution is suggested to use the values of \tan(\theta) and \sin(2\theta) to find the minimum value.
abender
Hi, fellas. In response to someone's request on another form to find the range of [tex] \sec^4(x)+\csc^4(x)[/tex], I offered the following solution and explanation:
kjchauhan said:
Please help me to find the range of [TEX]sec^{4}(x)+cosec^{4}(x)[/TEX].
Thanks in advance.
[TEX]\sec^4(x) = (\sec^2(x))^2 = (1+\tan^2(x))^2 = \tan^4(x) + 2\tan^2 + 1[/TEX]
[TEX]\csc^4(x) = (\csc^2(x))^2 = (1+\cot^2(x))^2 = \cot^4(x) + 2\cot^2 + 1 [/TEX][TEX]\sec^4(x) + \csc^4(x) = \tan^4(x) + 2\tan^2 + 1 + \cot^4(x) + 2\cot^2 + 1 [/TEX][tex] = \tan^4(x) + \cot^4(x) + 2(\tan^2(x)+\cot^2(x)) + 2[/tex]
The range of [TEX]\tan(x)[/TEX] is [TEX](-\infty, \infty)[/TEX]. Likewise, the range of [TEX]\cot(x)[/TEX] is [TEX](-\infty, \infty)[/TEX].
Since [TEX]\tan^4(x)[/TEX] and [TEX]\cot^4(x)[/TEX] are positive even powers, both have range [TEX][0,\infty)[/TEX].
BELOW is where others may disagree with me:
I contend that the range of [TEX]\tan^4(x)+\cot^4(x)[/TEX] is [TEX](0,\infty)[/TEX] as opposed to [TEX][0,\infty)[/TEX], which the sum of the parts may intuitively suggest.
The two ranges differ insofar [TEX](0,\infty)[/TEX] does not contain [TEX]0[/TEX], whereas [TEX][0,\infty)[/TEX] does contain [TEX]0[/TEX].
I believe that the range of [TEX]\tan^4(x)+\cot^4(x)[/TEX] should NOT include 0, i.e., it should be [TEX](0,\infty)[/TEX].
Proof is achieved if we show [TEX]\tan^4(x)+\cot^4(x)>0[/TEX] on the entire domain (reals that are not multiples of [TEX]\pi[/TEX]).
Both terms in [TEX]\tan^4(x)+\cot^4(x)[/TEX] are non-negative in the reals, so clearly the sum itself is non-negative.
[TEX]\tan^4(x)+\cot^4(x)[/TEX] cannot equal 0 because then either [TEX]\tan^4(x)=-\cot^4(x)[/TEX] (which per the line above is not possible) OR [TEX]\tan^4(x)=\cot^4(x)=0[/TEX], which also can't happen because [TEX]\cot^4(x)=\tfrac{1}{\tan^4(x)}[/TEX] and 0 cannot be a denominator.
As such, [TEX]\tan^4(x)+\cot^4(x)>0[/TEX].
And with this new information, [TEX]\sec^4(x) + \csc^4(x) = \underbrace{\left[\tan^4(x) + \cot^4(x)\right]}_{\text{always positive!}} + 2\underbrace{(\tan^2(x)+\cot^2(x))}_{\text{can show positive similarly}} + 2 > 2[/TEX].
It at long last follows that the range of [TEX]\sec^4(x) + \csc^4(x)[/TEX] is [TEX]\left(2,\infty\right)[/TEX].
If someone has an argument for a left bracket instead of my left open parenthesis, I'd love to hear it!
-Andy
Mathematics news on Phys.org
I checked first for the minima at W|A, and it suggests, that given:
$f(x)=\sec^4(x)+\csc^4(x)$
then the global minimum is $f(x)=8$, at:
$x=2(k\pi\pm\tan^{-1}(1\pm\sqrt{2}))$ where $k\in\mathbb{Z}$
Hi abender! :)
You are right that the range will not include zero.
The actual range is a subset of $[0,\infty)$, but also a subset of $(0,\infty)$.
Btw, the range is also not $(2,\infty)$.What you have, is:
$\sec^4 x + \csc^4 x = \dfrac{1}{\cos^4 x} +\dfrac{1}{\sin^4 x}$
This expression is always positive, and it tends to infinity at every multiple of $\dfrac \pi 2$.
Since cosine and sine are symmetric, it will take its lowest value at $\dfrac \pi 4$, where it takes the value 8.
So the range is $[8, \infty)$.
Wow! That is a pretty complex way of W|A to say $x=\dfrac \pi 4 + k \dfrac \pi 2$. (Giggle)
ILikeSerena said:
Wow! That is a pretty complex way of W|M to say $x=\dfrac \pi 4 + k \dfrac \pi 2$. (Giggle)
It sure is!...and I didn't bother to try to simplify either...(Tmi)
I simply noted that the range was different than the OP suggested and was going to let them go "back to the drawing board." (Smile)
Yes, I'm surprised that W|A did not give a simpler solution.
Either way, it's not easy to simplify.
I didn't know that $\arctan(\sqrt 2 - 1) = \dfrac \pi 8$.
And I wouldn't know how to figure it out in this direction (the other way around I'd use the double angle formulas).
So I learned something new today.
You aren't kiddin. Wow.
I feel stupid. I responded with a very very very very very rough lower bound. Who does this? "... plus 2 times something positive..." Of course I then end up with a superset of the range. Go Ravens!
Suppose we draw a right triangle, and with respect to one of the two acute angles (we'll call this angle $\theta$), we state:
$\tan(\theta)=\sqrt{2}-1$
and so:
$\displaystyle \sin(\theta)=\frac{\sqrt{2}-1}{\sqrt{2\sqrt{2}(\sqrt{2}-1)}}$
$\displaystyle \cos(\theta)=\frac{1}{\sqrt{2\sqrt{2}(\sqrt{2}-1)}}$
Now we may then state:
$\displaystyle \sin(2\theta)=2\sin(\theta)\cos(\theta)=\frac{2( \sqrt{2}-1)}{2\sqrt{2}(\sqrt{2}-1)}=\frac{1}{\sqrt{2}}$
Hence:
$\displaystyle 2\theta=\frac{\pi}{4}$
$\displaystyle \theta=\frac{\pi}{8}$
For fun I tried to find the common values for the trigonometric functions.
Wiki did not contain these specific values.
Now it does.
Find the range of [tex] \sec^4(x)+\csc^4(x)[/tex]...
$\displaystyle \sec^4 x+\csc^4 x=\frac{1}{\cos^4 x}+\frac{1}{\sin^4 x}$
By AM-GM inequality, we have
$\displaystyle \frac{\frac{1}{\cos^4 x}+\frac{1}{\sin^4 x}}{2} \ge \sqrt{\frac{1}{\cos^4 x}.\frac{1}{\sin^4 x}}$
$\displaystyle \frac{\frac{1}{\cos^4 x}+\frac{1}{\sin^4 x}}{2} \ge \frac{1}{\cos^2 x.\sin^2 x}$
$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{2}{\cos^2 x.\sin^2 x}$$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{2}{(\cos x.\sin x)^2}$
$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{2.2.2}{(2\cos x.\sin x)^2}$
$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{8}{\sin^2 2x}$
$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{8}{\frac{1-\cos 2x}{2}}$
$\displaystyle \frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge \frac{16}{1-\cos 2x}$
Since $\displaystyle 0 \le 1-\cos 2x \le 2 $, we can conclude that $\displaystyle\frac{1}{\cos^4 x}+\frac{1}{\sin^4 x} \ge 8 $, that is, the range of $\displaystyle \sec^4 x+\csc^4 x $ is [8, ∞).
FAQ: What Is the Range of sec^4(x) + csc^4(x)?
What is the range of sec^4(x) + csc^4(x)?
The range of sec^4(x) + csc^4(x) is all real numbers greater than or equal to 2. This can be represented as [2, ∞).
How do you derive the range of sec^4(x) + csc^4(x)?
To derive the range of sec^4(x) + csc^4(x), we can use the properties of trigonometric functions and their respective graphs. We know that sec^4(x) and csc^4(x) both have a minimum value of 1, and as x approaches ±∞, they approach 0. This means that the sum of these two functions will always be greater than or equal to 2.
Can the range of sec^4(x) + csc^4(x) ever be negative?
No, the range of sec^4(x) + csc^4(x) can never be negative. As mentioned before, the minimum value of both sec^4(x) and csc^4(x) is 1, and when added together, the result is always greater than or equal to 2.
Is there a specific interval where the range of sec^4(x) + csc^4(x) is defined?
No, the range of sec^4(x) + csc^4(x) is defined for all real numbers greater than or equal to 2, so there is no specific interval where it is defined. However, it is important to note that the function is undefined for certain values of x, such as when x = π/2 + nπ or x = nπ, where n is any integer.
How can the range of sec^4(x) + csc^4(x) be applied in real-life situations?
The range of sec^4(x) + csc^4(x) can be applied in various fields such as physics, engineering, and astronomy. It can be used to model oscillations, vibrations, and other periodic phenomena. Additionally, it can be used to determine the maximum and minimum values of a system or function in these fields.
