What is the rate of change of the area of a rectangle?
And, of course, be careful with units -- I would write ##A' = 6ww' \frac {cm^2} {sec}##.In summary, we are trying to find the rate of change of the area of a rectangle, given that its area is 75cm^2 and its length is 3 times its width. The rate of change of the width is 2cm/second. By setting up the related rate equation A' = 6ww', where w is the width and w' is the rate of change of the width, we can solve for A' by plugging in the values of w and w' when A = 75cm^2. This results in A' =
a78
Find the rate of change of the area of a rectangle whose area is 75cm^2. The length is 3 times the width. The rate of change of the width is 2cm/second.
A=75 A'=?
L=3x= 15 L'=6
W=x=5 W'=2
A'=L'W+LW'
A'= (6)(5)+ (15)(2)
A'=60cm/sec
And it looks like homework, so use the template and show your attempt!
Likes a78
Much better ! The problem statement helps you to formulate what you actually need to solve.
easiest if you express the rate of change as a ##d\over dt##, as you did.
Do not forget to keep track of the units: an area is cm2, so a growth rate for an area can not be cm/s !
Other than that, you are doing quite well !
Likes a78
While you seem to understand how to work this problem, your writeup could be much better. I will intersperse comments below.
A rectangle whose area is ##75## has constant area, so that isn't what you mean. What you mean is a rectangle has length 3 times its width, so its area is ##A = lw =3w^2##. The rate of change of ##w## is ##2##, and you want the rate of change of ##A## when its area is ##75##.
A=75 A'=?
L=3x= 15 L'=6
W=x=5 W'=2
Again, the derivative of constants are zero.
A'=L'W+LW'
A'= (6)(5)+ (15)(2)
A'=60cm/sec
Since you already have the correct answer, I am going suggest a better way to write it up. Since you have ##A = 3w^2## you know that ##A' = 6ww'##, where ##' = \frac d {dt}##. That is called the related rate equation -- everything is a function of ##t## so the derivatives aren't ##0##. At the instant when ##A = 75##, you have figured out that ##w = 5## and ##w'## is given as ##2##. Just put those numbers in the related rate equation and you have your answer.
Likes a78
Related to What is the rate of change of the area of a rectangle?
The rate of change of the area of a rectangle refers to how quickly the area of the rectangle is changing with respect to its dimensions, such as length and width.
What is the formula for calculating the rate of change of the area of a rectangle?
The formula for calculating the rate of change of the area of a rectangle is:
Rate of change of area = (change in area) / (change in dimension)
This formula can also be written as:
Rate of change of area = (new area - initial area) / (new dimension - initial dimension)
How is the rate of change of the area of a rectangle related to its perimeter?
The rate of change of the area of a rectangle is directly proportional to its perimeter. This means that as the perimeter of a rectangle increases, the rate of change of its area also increases.
Can the rate of change of the area of a rectangle be negative?
Yes, the rate of change of the area of a rectangle can be negative. This happens when the dimensions of the rectangle are decreasing, resulting in a decrease in the area of the rectangle.
How is the rate of change of the area of a rectangle used in real-life situations?
The rate of change of the area of a rectangle is used in various real-life situations, such as in construction and engineering. It helps in determining the amount of materials needed for a project and how they will change as the dimensions of the rectangle are adjusted.
