What Is the Ratio of Area to Perimeter for a Rug with Length 9w?
Then the length is 9w. The area is (9w)(w+ 5)= 9w^2+ 45w. The perimeter is 2(9w)+ 2(w+ 5)= 18w+ 10. The ratio of the area to the perimeter is (9w^2+ 45w)/(18w+ 10).
Kathleen217744
The length of a rug is eight times greater then the width. if the width of the rug is (w+5), what is the ratio of the area of the rug to the perimeter of the rug in simplest form?
Mathematics news on Phys.org
Re: help
Hi, welcome to the forum!
Let's write out what we know.
$width = w + 5$
The length is also given, but it's been disguised a little bit.
This just translates to, $length = 8 \cdot width = 8 \cdot (w + 5)$.
Now we have everything we need from the question, let's look at the next part.
Let's focus first on finding the area of the rug, and the perimeter of the rug.
area of rug $= A = length \cdot width = 8(w + 5)(w + 5) = 8(w + 5)^2$.
perimeter of rug $= P = 2 \cdot length + 2 \cdot width = 2w + 10 + 16w + 80 = 18w + 90 = 18(w + 5)$.
Finally, the question asks for the ratio of the area to the perimeter. Let's call the ratio R.
Then, $R = A:P = \dfrac{A}{P} = \dfrac{8(w + 5)^2}{18(w + 5)^1}$
Can you finish it off? :)
"8 times the width" would be 8w but I would interpret "8 times greater than the width" as "the width plus 8 times the width"- w+ 8w= 9w.
FAQ: What Is the Ratio of Area to Perimeter for a Rug with Length 9w?
What is the definition of the ratio of area to perimeter?
The ratio of area to perimeter is a mathematical comparison between the size of a two-dimensional shape's surface area and the length of its boundary. It is expressed as a fraction or decimal and can be used to compare the "compactness" of different shapes.
How is the ratio of area to perimeter calculated?
The ratio of area to perimeter is calculated by dividing the area of a shape by its perimeter. For example, if a rectangle has an area of 20 cm^2 and a perimeter of 16 cm, the ratio of area to perimeter would be 20/16 = 1.25.
What does a high or low ratio of area to perimeter indicate about a shape?
A high ratio of area to perimeter indicates that a shape has a larger area relative to its perimeter, meaning it has a more spread out and less compact shape. A low ratio indicates that a shape has a smaller area relative to its perimeter, meaning it has a more compact and less spread out shape.
How can the ratio of area to perimeter be used in real-world applications?
The ratio of area to perimeter can be useful in various fields such as architecture, engineering, and biology. In architecture, it can help determine the most efficient use of space in a building design. In engineering, it can aid in optimizing the design of structures for the most stability. In biology, it can be used to compare the shapes of different organisms and their adaptations.
Can the ratio of area to perimeter be greater than 1?
Yes, the ratio of area to perimeter can be greater than 1. This indicates that the area of the shape is larger than its perimeter, which is common for shapes with curved edges such as circles or ellipses. In fact, the ratio of area to perimeter is infinite for a perfect circle as it has no defined perimeter.
