MHB What is the ratio of PA to PB on a semicircle with points A and B on the x-axis?
  • Thread starter Thread starter mathdad
The discussion centers on finding the ratio of distances PA to PB on a semicircle defined by the equation y = sqrt{1 - x^2}, with points A and B located on the x-axis at coordinates (a, 0) and (1/a, 0), respectively. The arbitrary point P is located on the semicircle in quadrant 2, with coordinates (x, sqrt{1 - x^2}). The distances from P to A and P to B are calculated using the distance formula, resulting in d(PA) = sqrt{a^2 - 2ax + 1} and d(PB) = (sqrt{a^2 - 2ax + 1})/a. The ratio PA/PB simplifies to a, confirming that PA is proportional to the value of a. The conclusion demonstrates the relationship between the distances and the parameter a.
mathdad
Semicircle y = sqrt{1 - x^2} is given as a graph on the xy-plane. Points A and B lie on the line y = 0. The x-coordinates of the points A and B are a and 1/a, respectively. Point P is an arbitrary point on the graph of y in quadrant 2 connecting to points A and B. Show that PA/PB = a.
Note: Assume that 0 < a < 1
Obviously, I need to find the distance from P to A and the distance from P to B.
Point A = (a, 0)
Point B = (1/a, 0)
I do not know the coordinates of point P.
I am stuck here.
Mathematics news on Phys.org
the coordinates of point P are $(x, \sqrt{1-x^2})$ ...
Thank you for providing the coordinates of point P.
Let d(PA) = distance from P to A.
After plugging into the distance formula for points on the xy-plane, and simplifying the radicand, I found d(PA) to be sqrt{a^2 - 2ax + 1 }.
Let d(PB) = distance from P to B.
Applying the same steps as before, I found d(PB) to be
(sqrt{a^2 -2ax + 1})/a.
PA/PB = a
[sqrt{a^2 - 2ax + 1}]/[sqrt{a^2 - 2ax + 1 }]/a = a
sqrt{a^2 - 2ax + 1 } • a/sqrt{a^2 - 2ax + 1 } = a
a = a
Done!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
