What is the reaction force between the ring and the hoop?
In summary, the equation for the normal force N in this scenario is N cos θ = mg. However, there is an interesting result where cosθ cannot be larger than 1, but the right hand side g/(ω2r) can be larger than 1 if ω is small enough. This suggests that there may be a limit to the value of ω in order for the equation to hold true.
Olivia Lam
A circular hoop rotates with uniform angular velocity w about a vertical diameter AOB, O being the center. A smooth ring P of mass m can slide on the hoop. If θ be the angle of inclination of the radius OP to the vertical when the ring is in equilibrium with respect to the hoop, (a) find cos θ in terms of the radius of the hoop r, angular velocity w and g. (b) Find the reaction force between the ring and the hoop.
N cos θ=mg
N sin θ=mrw^2 sin θ
cos θ=g/rw^2
a.)N cos θ=mg
N sin θ=mrw^2 sin θ
cos θ=g/rw^2
b.) My question is reaction force =N ? or =F=mg tanθ ?
If it is N then N=mg cosθ =mg^2/r w^2 or N=mg/cosθ =mrw^2 ?
Thank you
I would interpret "the reaction force between the ring and the hoop" to be the normal force N.
Your answer to (a) looks good.
Likes Olivia Lam
Thank you! Then N=mg cosθ =mg^2/r w^2 ?
Check your work here. Note that you had the correct equation Ncosθ = mg in your first post.
Also, there is something interesting about the result for part (a): cosθ = g/(ω2r).
cosθ cannot be larger than 1. But the right hand side g/(ω2r) can be larger than 1 if ω is small enough. What do you conclude from this?
Related to What is the reaction force between the ring and the hoop?
1. What is the definition of reaction force?
Reaction force is the force that is exerted on an object in response to an applied force. It is equal in magnitude and opposite in direction to the applied force.
2. How is the reaction force between the ring and the hoop calculated?
The reaction force between the ring and the hoop can be calculated using Newton's third law of motion, which states that for every action, there is an equal and opposite reaction. This means that the force exerted by the ring on the hoop is equal in magnitude and opposite in direction to the force exerted by the hoop on the ring.
3. Does the reaction force between the ring and the hoop depend on the materials of the objects?
Yes, the reaction force between the ring and the hoop can depend on the materials of the objects. This is because different materials have different properties, such as elasticity and friction, which can affect the way the forces are exerted on each other.
4. Can the reaction force between the ring and the hoop change during the interaction?
Yes, the reaction force between the ring and the hoop can change during the interaction. This can happen if there are external forces acting on either the ring or the hoop, or if the materials of the objects deform or change in some way during the interaction.
5. How does the reaction force between the ring and the hoop affect their motion?
The reaction force between the ring and the hoop can affect their motion by causing them to accelerate or decelerate, change direction, or deform. This force can also play a role in determining the final position and velocity of the objects after the interaction.
