What is the real power of a generator
In summary, the individual was having issues with their newly purchased Subaru 1700i inverter generator from eBay. The AC 240 outlet did not work, but the DC 12V outlet did. They attempted to use a small inverter and a halogen light, but the inverter burned out. They have now purchased a stronger inverter and are questioning the power of their generator when using the DC 12V outlet. They also asked if it is safe to use the DC 12V outlet with an inverter for running lights, even though the generator is only recommended for charging batteries. The expert recommends returning the item to the seller for a refund, or contacting eBay for assistance. They also clarify that the DC outlet is only
Ebay_Dreamer
I have problem after purchasing a Subaru 1700i inverter generator on ebay. The AC 240 doesn't work but the DC 12V works. It is written on the DC 12V "Only for battery charge"
I tried to put a small inverter and a 230W halogen light directly on the battery + and - . The light started to work but suddenly the small inverter suposed to transform 12V into 240V start burning and was blow off.
I have decided to buy a stronger invereter. I found one 1500W on ebay in Chine for only $50. I hope it will work.
My question is: What is the power of my generator if using the DC12V exit. It is written on the generator 12V 8.3Amp. The generator is supposed to provide 1700W using the AC 240.
Do you think it is a good idea to use the DC12 and add an inverter at the end ?
thx,
I would think you should return it to the seller for a refund, unless its description included "does not work". If the seller does not want to refund your money, notify ebay that the item did not work and ask for their advice. (They probably have a FAQ covering this.)
12*9.3 = 99 watts (maximum)
1700W relates to the AC outlet. The DC outlet is rated for only 99W.
Do you think it is a good idea to use the DC12 and add an inverter at the end ??
That is not an efficient way to obtain 240V. And it can never supply more than about 75W, because in practice the inverter loses some energy.
Thanks for your answer. No Ebay return because it was said spare and repair No return.
I really got it cheap for only $50 so not a such bad deal.
If I plug a 240V inverter which will transform the 12V into 240V at the exit of the DC 12V.
Is the 240V power still around 100 watt or could it be 240*8.3= around 1700 watts.
I was thinking that it would be for each Volt 8.3Am/12V=around 0.7amp for each volt and therefore for 240V around 150W.
I was dreaming it could be 8.3Amp * 240V but it seems that 8.3Amp is for 12V and not for each Volt.
Anyway, I have found in the neighborhood a friend who know a mechanics who said it could be fixed for only $50.
I have also purchased an 1500 watts inverter and will post here the result of my test. I will plug the inverter in the DC and switch on as many halogen bulbs as it could. This could be stupid but maybe the Amp will go up if more demand. I am only afraid to blow up my generator if using the DC 12V and not the recommend 240 V plug !
Do you think it is a risk for the generator to use the DC 12V with an inverter for running lights because it is written on the generator that the DC 12 should only be used for charging battery ?
yes
never
Anyway, I have found in the neighborhood a friend who know a mechanics who said it could be fixed it easily for $50. Hope it would work
If the damage was in the item before it was shipped, you may be able to get the cost of repair refunded by the seller. Email and ask first, before you post negative feedback.
The real power of a generator is determined by its wattage rating, which is a measure of the maximum amount of electrical power it can produce. In this case, the Subaru 1700i inverter generator is rated for 1700 watts when using the AC 240 outlet. However, when using the DC 12V outlet, the power output is limited to 12 volts and 8.3 amps, which equals to a maximum of 99.6 watts. This is significantly lower than the AC 240 output.
It is important to note that the DC 12V outlet is only intended for charging batteries and not for powering larger electrical devices. Attempting to power a 230W halogen light and a small inverter directly from the battery may have caused damage to the inverter due to the limited power output.
Using a stronger inverter may work, but it is not recommended as it may put strain on the generator and potentially cause damage. It is best to use the generator as intended, with the appropriate outlets, to avoid any potential safety hazards.
In summary, the power of your generator is 1700 watts when using the AC 240 outlet. It is not recommended to use the DC 12V outlet and add an inverter at the end as it may cause damage to the generator and any connected devices. It is important to follow the manufacturer's instructions and use the appropriate outlets for the intended purposes.
FAQ: What is the real power of a generator
What is the purpose of a generator?
A generator is a device that converts mechanical energy into electrical energy. It is used to provide backup power during power outages or in areas where there is no access to electricity.
How does a generator work?
A generator works on the principle of electromagnetic induction. It consists of a rotor, which rotates within a stator. As the rotor spins, it creates a magnetic field and induces an electrical current in the stator windings, producing electricity.
What is the real power output of a generator?
The real power output of a generator depends on its size, design, and the type of fuel it uses. Generally, a generator's power output is measured in watts, and it can range from a few hundred watts to several megawatts.
Can a generator power an entire house or building?
Yes, a generator can power an entire house or building depending on its size and power output. However, it is important to note that not all appliances and systems can be powered simultaneously, and the generator's power capacity should be carefully considered.
How do I choose the right generator for my needs?
The right generator for your needs will depend on the amount of power you require and the type of appliances or systems you want to power. It is important to carefully consider your power needs and consult with a professional to choose the right generator for your specific situation.
