JC2000
- 186
- 16
The problem :
A variable line, drawn through the point of intersection of the straight lines ##(x/a)+(y/b) = 1## and ##(x/b)+(y/a)=1##, meets the coordinate axes in A & B . We have to Show that the locus of the mid point of AB is the curve ##2xy(a + b) = ab(x + y)##.
The solution :
Let ##(h, k)## be the coordinates of the mid-point of the line ##AB##, then it will intersect the coordinate axes at the points ##A(2h, 0)## & ##B(0, 2k)## respectively hence line ##AB## has x-intercept ##2h## & y-intercept ##2k##,
Now, the equation of the line ##AB## is given using the intercept form as $$\frac{x}{2h}+\frac{y}{2k}=1\tag 1$$
Now, since the line ##AB## passes through the intersection of the lines: ##\frac{x}{a}+\frac{y}{b}=1## & ##\frac{x}{b}+\frac{y}{a}=1## hence the coordinates of the intersection point are ##\left(\frac{ab}{a+b}, \frac{ab}{a+b}\right)## which can be substituted into (1),
$$\frac{\frac{ab}{a+b}}{2h}+\frac{\frac{ab}{a+b}}{2k}=1$$
$$\frac{1}{h}+\frac{1}{k}=\frac{2(a+b)}{ab}$$
or $$\frac{h+k}{hk}=\frac{2(a+b)}{ab}$$
or $$2hk(a+b)=ab(h+k)$$ Now, substitute ##h=x## & ##k=y## in the above equation, the locus of the mid-point of line ##AB##
is given as follows $$\color{red}{2xy(a+b)=ab(x+y)}$$
My Question :
If the problem is attempted using ##(h/2,k/2)## as the coordinates of the mid-point of ##AB## then the result is as follows :$$\color{red}{xy(a+b)=ab(x+y)}$$ (if I use ##h=x## and ##y=k##.
I am unable to get my head around why ##x=2h## and ##y=2k## in this scenario?
The solution :
My Question :
