What is the reason for the derivative of arcsin(x) not being -1/sqrt(1-x^2)?
  • MHB
  • Thread starter Petrus
  • Tags
    Derivative
In summary, the conversation discusses the derivative of $\arcsin(x)$ and the reason why it cannot be $-\frac{1}{\sqrt{1-x^2}}$. The range of $\arcsin$ is defined to be from $-\pi/2$ to $+\pi/2$, making its derivative always positive. Choosing a different range would result in a different inverse for the sine function.
Petrus
702
Hello MHB,
derivate \(\displaystyle \sin^{-1}(x)\)So I use the derivate formula for invers and get
\(\displaystyle \frac{1}{\cos(\sin^{-1}(x))}\)
and Then draw it and get \(\displaystyle \frac{1}{\sqrt{1-x^2}}\)
but there is a reason WHY it can't be \(\displaystyle -\frac{1}{\sqrt{1-x^2}}\) and I did not understand it, I did not get it.
Regards,
\(\displaystyle |\pi\rangle\)
Re: Derivate of arcsin(x)
Petrus said:
Hello MHB,
Regards,
The $\arcsin$ is defined to have a range of $-\pi/2$ to $+\pi/2$.
With this definition the derivative is always positive.
You can also choose the range to be different, making the derivative negative, but then it's not an $\arcsin$ anymore. Then you have a different inverse for the sine.
FAQ: What is the reason for the derivative of arcsin(x) not being -1/sqrt(1-x^2)?
What is the derivative of arcsin(x)?
The derivative of arcsin(x) is equal to 1/sqrt(1-x^2).
How do you find the derivative of arcsin(x)?
To find the derivative of arcsin(x), you can use the chain rule and the derivative of sin(x) which is cos(x). The product of these two gives you 1/sqrt(1-x^2).
Why is the derivative of arcsin(x) important?
The derivative of arcsin(x) is important because it allows us to find the slope of a curve at any point on the arcsin(x) function. This is useful in many applications, such as optimization problems and calculating rates of change.
Is the derivative of arcsin(x) the same as the derivative of sin(x)?
No, the derivative of arcsin(x) and sin(x) are not the same. While the derivative of sin(x) is cos(x), the derivative of arcsin(x) is 1/sqrt(1-x^2).
Can you provide an example of using the derivative of arcsin(x) in real life?
Yes, the derivative of arcsin(x) can be used in real life to determine the angle of inclination of a ramp or road. By finding the slope of the curve at any point on the arcsin(x) function, we can determine the angle at which the ramp or road is inclined.
