What is the relation between unitary group, homotopy?
In summary, the O(N) nonlinear sigma model has topological solitons only when N=3 in the planar geometry. There exists a generalization of the O(3) sigma model so that the new model possesses topological solitons for arbitrary N in the planar geometry. It is the CP^{N-1} sigma model,†whose group manifold isCP^{N-1}=ƒ U(N)/†[U(1)\bigotimes U(N-1)]‡ =SU(N)/[†U(1)\bigotimes SU(N)\bigotimes SU(N-1)
PRB147
127
The O(N) nonlinear sigma model has topological solitons only when N=3 in the
[tex]CP^{N-1}=ƒ U(N)/†[U(1)\bigotimes U(N-1)]‡ =SU(N)/[†U(1)\bigotimes SU(N)\bigotimes SU(N-1)‡][/tex]
The homotopy theorem tells
[tex] \pi_2(CP^{N-1})=Z [/tex]
since [tex]\pi_2(G/H)…=\pi_1(„H)…[/tex] (when G is simply connected) and [tex]\pi_n(„G\bigotimes G')=\pi_n… („G)\bigoplus \pi_n(„G') [/tex]…. It is also called the SU(N) sigma model.
I don't understand the following sentences, what is the meaning of the following math expression?Would anyone gives a more detailed hints to the following sentences:
U(N) seems to be not simply connected.
What sort of mathematical objects are the ##U(N)## and ##SU(N)## items? If they are vector or tensor spaces, the expression with the ##\otimes## symbols can be interpreted as a tensor product.
U(N),SU(N) are unitary and special unitary group respectively
Based on this, I would guess that the ##\otimes## symbol is supposed to indicate semidirect product, which is more usually denoted by ##\rtimes##. The link gives an identification of ##U(1)## with a subgroup of ##U(N)##, and we could use the same principle to identify ##U(N-1)## with a subgroup, viz the group of ##n\times n## matrices formed by adding a row of zeros above and column of zeros to the left of a matrix in ##U(N-1)## and then putting a 1 in the top-left cell. Then we can take the semidirect product of those two subgroups.
Likes PRB147
Thank you very much, I admire mathematician!
The correct expressions are
##CP^{n-1} = U(n)/(U(n-1)##x##U(1)) = SU(n)/S(U(n-1)##x##U(1))## where x means direct product(not semi direct product) of groups algebraically and Cartesian product topologically.
##\bigotimes## usually means tensor product which in this case is meaningless.
From the long homotopy sequence of the fibration, ##U(1)\rightarrow S^{2n-1}\rightarrow CP^{n-1}## one has
##π_2(S^{2n-1})\rightarrow π_2(CP^{n-1})\rightarrow π_1(U(1)) \rightarrow π_1(S^{2n-1})## it follows that ##π_2(CP^{n-1}) = Z## since the homotopy groups of the 2n-1 sphere are zero below dimension 2n-1 and the fundamental group of the circle is Z.
##SU(n)## is simply connected which can be shown by induction starting with ##SU(1)## which is the trivial group. From the long exact sequence of the fibration,
## S(U(n-1)##x##U(1))\rightarrow SU(n)\rightarrow CP^{n-1}## one has
## π_2(SU(n))\rightarrow π_2(CP^{n-1})\rightarrow Z \rightarrow 0##
You need to show that ## π_2(SU(n))## is zero.
BTW: ##U(n)## is not simply connected. The complex determinant defines a continuous homomorphism from ##U(n)## onto ##U(1)## with kernel ##SU(n)##. Since ##SU(n)## is simply connected, the exact sequence of the fibration shows that ##π_1(U(n)) = Z##.
Likes WWGD, PRB147 and mathwonk
Thank You very much lavinia for your great answer!
Lavinia wrote "You need to show that π2(SU(n)) is zero."
It is an interesting fact that for any Lie group G at all, π2(G) = 0. This is a rather deep fact using algebraic topology.
A somewhat simpler fact is that, loosely speaking, a Lie group resembles the cartesian product of odd-dimensional spheres. The precise statement is somewhat technical, but it is an amazing theorem:
The rational cohomology ring H*(G; ℚ) of a Lie group G is the same as the rational cohomology ring of some product of odd-dimensional spheres.
(This is "simpler" in the sense that its proof follows from the easy-to-prove observation that the cohomology ring of a Lie group is a Hopf algebra.)
For some examples:
H*(U(n); ℚ) = H*(S1 × S3 × ... × S2n-1; ℚ)​
H*(SU(n); ℚ) = H*(S3 × S5 × ... × S2n-1; ℚ)​
H*(Sp(n); ℚ) = H*(S3 × S7 × ... × S4n-1; ℚ)​
Likes lavinia and PRB147
Related to What is the relation between unitary group, homotopy?
What is the unitary group?
The unitary group, denoted as U(n), is a mathematical group consisting of all n-by-n unitary matrices. A unitary matrix is a square matrix whose complex conjugate transpose is equal to its inverse. The unitary group is important in various fields of mathematics, including representation theory, differential geometry, and algebraic topology.
What is homotopy?
Homotopy is a fundamental concept in topology, which studies the properties of geometric objects that are preserved under continuous deformations. In simple terms, two objects are homotopic if one can be continuously deformed into the other without tearing or gluing. Homotopy theory is used to classify topological spaces and study their properties.
What is the relation between unitary group and homotopy?
The unitary group and homotopy are related in several ways. First, the unitary group is a topological group, meaning that it has a natural topology that is compatible with its group operations. This topological structure allows for the study of continuous deformations, which is essential in homotopy theory. Additionally, the unitary group can be seen as a special case of a more general concept known as a Lie group, which plays a crucial role in understanding smooth manifolds and their homotopy properties.
How is the unitary group used in physics?
The unitary group is widely used in physics, particularly in quantum mechanics. In this context, the unitary group represents the set of all possible transformations that preserve the inner product of quantum states. This group is used to describe the symmetries of various physical systems, such as atoms and molecules, and plays a crucial role in the development of quantum field theory.
What are some applications of homotopy theory?
Homotopy theory has numerous applications in mathematics and other fields, including physics and computer science. In mathematics, it is used to study the properties of topological spaces, classify manifolds, and investigate algebraic structures such as groups and rings. In physics, homotopy theory is used to study the properties of physical systems and their symmetries. In computer science, it has applications in data analysis, machine learning, and computer graphics.
