What is the relationship between gravity and density?
In summary, the relationship of gravity to density is that the more dense an object is, the more gravity it has. The stronger the gravity, the closer to the object's center of mass it is. The sun's gravity is more than Earth's, even though the intensity of the sun is less than the density of the Earth.
muneer Mohsen samih
What is the relationship of gravity to density?
In black holes the cause of gravity is that the star shrinks and becomes dense.
But Jupiter's gravity is more than the Earth's gravity, although its density is lower?
Is the sun's gravity more than the Earth's gravity, even though the intensity of the sun is less than the density of the earth?
I wanted to help explain in detail so I understand
If you are far away, the density is irrelvant, only the mass matters. See below regarding density.
No, absolutely not. The cause of gravity is the mass.
My point exactly. Gravity is a function of MASS, not density. The place where density comes in is that for dense objects, you can get closer to the center of mass than if they were less dense.
Of course the sun's gravity is more than Earth's. The sun is WAY heavier than the Earth.
Likes davenn
Both Jupiter and the Sun are composed mainly of gaseous substances, which are much less dense than solids are. The Earth and the other inner planets are composed of rocky materials and metals. This gives a much higher density than gas giants and stars, even though the overall mass is much lower for the Earth.
Yes. If you go out to a certain radius from the Earth or from the Sun, you will find that the Sun's gravity is much, much stronger than the Earth's. It's only stronger here on Earth because we are within a few thousand kilometers of the center of mass of the Earth, but millions of kilometers from the Sun.
I think he means that the star shrinks and becomes more dense, leading to higher gravity near the star (black hole). Not that the source of the gravity is the density.
Well, I was careful to point out that proximity matters, for that very reason.
Likes Drakkith
In Newtonian gravity the relationship is ##\nabla \cdot \mathbf{g} =-4\pi G \rho##
In GR that is just one component of gravity, so it is still approximately true but there are additional terms required for extreme situations
thanks for you
also
Is there a program that calculates and solves the equations of tensor?
Gravity acts on the centre of gravity which is normally the centre of the core. Sun's core must be denser than Earth's core. Sun's core 150g/cm3 and Earth's core is just 12.8 g/cm3. Gravity acts as if all the mass is concentrated in the center of gravity even if the weight is distributed over large expanses of space.
Objects density has to do a lot with gravity because black holes have very high gravity because all of their mass is inside a small volume of space.
A lot to do with surface gravity because the surface is closer to the core. Utterly irrelevant to gravity at a distance.
[One assumes that we are holding mass fixed and varying density rather than holding volume fixed and varying density]
This effect is on the surface only, but there is a question how can the black hole eat the galaxies and the galaxies are away from it?
The black hole The gravitational force is excessive at the surface when a radius less than the radius when it was a star but how it will affect the galaxies away from it , which is far beyond the radius of the star before it dies and be a black hole
Holding mass fixed a denser object will have larger internal pressure and more gravity won't it?
Cheers
Cheers
No. It's the MASS that creates gravity, not density. True, you get a SURFACE gravity that higher with a denser object but so what? Jbriggs already pointed this out and so did I.
If you start off with X grams and it condenses to a 1 meter ball, that has a certain gravity and if it condenses to a 1cm ball, it still has the same gravity (again, SURFACE gravity is higher but that doesn't seem to be what you are asking about)
it doesn't
it won't
Likes nasu
Thanks for your reply. The source of gravity is the stress-energy tensor not just mass (I know you know this), isn't the pressure inside the smaller ball larger?
Cheers
Cheers
Yes, it is, but since in my example, both final sized balls started off with the same mass, they have to end up with the same gravity. The contributions to the stress energy tensor in each case ultimately all comes from the original mass.
The ultimate example of this would be that far from the surface, it doesn't matter whether a given amount of mass is from a really large star or from a black hole of the same mass.
Likes davenn
Related to What is the relationship between gravity and density?
1. What is gravity and how does it relate to density?
Gravity is a fundamental force of nature that causes objects with mass to attract each other. The more mass an object has, the stronger its gravitational pull. Density, on the other hand, is a measure of how much mass is packed into a certain volume. The relationship between gravity and density is that the more dense an object is, the stronger its gravitational pull will be.
2. How does gravity affect the density of objects?
The force of gravity affects the density of objects by compressing them. When an object is subjected to the force of gravity, it can cause the particles within the object to be pushed closer together, resulting in an increase in density. This is why objects on Earth, which has a strong gravitational pull, are more dense compared to objects on the moon, which has a weaker gravitational pull.
3. Is there a direct correlation between an object's density and its gravitational pull?
Yes, there is a direct correlation between an object's density and its gravitational pull. As mentioned before, the more dense an object is, the stronger its gravitational pull will be. This means that objects with higher densities will have a stronger pull towards each other compared to objects with lower densities.
4. How does the density of a planet affect its gravitational pull?
The density of a planet plays a significant role in determining its gravitational pull. Planets with higher densities, such as Earth, will have a stronger gravitational pull compared to planets with lower densities, such as Saturn. This is why objects on Earth feel heavier than objects on Saturn, even though Saturn is much larger in size.
5. Can the gravitational pull of an object change if its density changes?
Yes, the gravitational pull of an object can change if its density changes. As mentioned earlier, the more dense an object is, the stronger its gravitational pull will be. If the density of an object changes, its gravitational pull will change accordingly. For example, if an object is compressed, its density will increase, resulting in a stronger gravitational pull.
  • Thermodynamics
  • Astronomy and Astrophysics
  • Other Physics Topics
  • General Discussion
