What is the relationship between Mach number and compressibility in fluids?
In summary, Mach number is a quantity that expresses how compressible a fluid is. By definition, it requires a large amount of force to start the motion in fluid. Compressibility resistance is small, meaning the fluid is compressible. Reynolds number measures how viscous the flow is.
davon806
148
Hi,
The below website states the definition of Mach number, which is a quantity that expresses how compressible a fluid is.
https://physics.info/turbulence/
M = sqrt [ ( inertial resistance in the fluid ) / ( compressional resistance in the fluid ) ]
= v / c
If M is very large, then a fluid is traveling really fast. By the definition in the website, it is equivalent to saying that it requires a large amount of force to start the motion in fluid. By the definition of M, we can also say the compressional resistance is small, i.e. the fluid is compressible.
However, I don't see why the quantities are related: What does it have to do with an object that needs a huge amount of force to move it, to its compressibility ? It would be really helpful if someone can explain the physical picture of velocity ratio , in the role of determining the compressibility of a fluid.Thanks in advance
In corporated in (1)
No, it is not. You have completely mis-read the article.
It doesn't. Again, you have misread the article and you are mixing up the Reynolds number and the Mach number.
So what does M mean?
BTW, Reynolds number measures how viscous the flow is ( from https://www.grc.nasa.gov/www/BGH/reynolds.html).
"The Mach number is the most important parameter in compressible flow analysis. " (from http://nptel.ac.in/courses/112104118/38).
I was just trying to understand the reason of why M is defined as inertia force/ compressibility force, I understand that if a fluid requires a huge force to compress it then M is small.
I am struggling to understand why inertia and compressible force is the quantity determining how compressible a fluid is. Why can't the numerator in M be other quantites like gravity or pressure?
(from P.250 in this book
https://books.google.co.uk/books?id=p7WsoU-CfPkC&pg=PA250&lpg=PA250&dq=mach+number+compressibility+inertia&source=bl&ots=7s1x8ExeAd&sig=lZDCOs5K2wGaCflWNlWManjLuR4&hl=en&sa=X&ved=0ahUKEwjZ1KHek6DZAhVC2aQKHRBTCD04ChDoAQhPMAY#v=onepage&q=mach number compressibility inertia&f=false )
And what is the physical picture that if a fluid is traveling fast, then we should not ignore the compressible effect on it ?
Related to What is the relationship between Mach number and compressibility in fluids?
1. What is the definition of Mach number?
The Mach number is a unitless measure of the speed of an object in a fluid medium, relative to the speed of sound in that medium.
2. How is Mach number calculated?
Mach number is calculated by dividing the speed of the object by the speed of sound in the medium, with both speeds measured in the same units.
3. What is the significance of Mach number in aerodynamics?
Mach number is important in aerodynamics because it determines the compressibility of a fluid and how shock waves form around an object moving through the fluid.
4. What is the difference between supersonic and subsonic Mach numbers?
A subsonic Mach number is any number less than 1, meaning the object is traveling slower than the speed of sound. A supersonic Mach number is any number greater than 1, meaning the object is traveling faster than the speed of sound.
5. How does Mach number relate to the speed of an object in air?
The Mach number is a measure of the object's speed relative to the speed of sound in air. For example, a Mach number of 2 means the object is moving at twice the speed of sound in air.
  • Classical Physics
  • General Engineering
  • Classical Physics
  • Mechanical Engineering
15K
9K
