What is the Relationship Between Roots and Coefficients in a Quadratic Equation?
  • MHB
  • Thread starter mathdad
In summary, precalculus courses rarely cover the concept of sum and product of roots, unless it is an honors course. However, Skeeter demonstrated a method for finding these values using the quadratic formula, which involves manipulating the equation to find the desired values.
mathdad
1,283
I found this question to be interesting.
It is probably never introduced in a precalculus course unless it is an honor precalculus course in high school or college.
Mathematics news on Phys.org
note ... $\alpha + \beta = -\dfrac{b}{a}$ and $\alpha \cdot \beta = \dfrac{c}{a}$
$(\alpha + \beta)^2 = \dfrac{b^2}{a^2}$
$\alpha^2 + 2\alpha\beta + \beta^2 = \dfrac{b^2}{a^2}$
$\alpha^2 + \beta^2 = \dfrac{b^2}{a^2} - \dfrac{2c}{a} = \dfrac{b^2 - 2ac}{a^2}$
Skeeter showed that it is not something you must do but you certainly can do it that way.
With [tex]\alpha= \frac{-b+ \sqrt{b^2- 4ac}}{2a}[/tex], [tex]\alpha^2= \frac{b^2- 2b\sqrt{b^2- 4ac}+ b^2- 4ac}{4a^2}[/tex].
With [tex]\beta= \frac{-b- \sqrt{b^2- 4ac}}{2a}[/tex], [tex]\beta^2= \frac{b^2+ 2b\sqrt{b^2- 4ac}+ b^2- 4ac}{4a^2}[/tex].
Adding the two, the [tex]-2b\sqrt{b^2- 4ac}[/tex] and [tex]2b\sqrt{b^2- 4ac}[/tex] cancel leaving
[tex]\alpha^2+ \beta^2= \frac{4b^2- 8ac}{4a^2}= \frac{b^2- 2ac}{a^2}[/tex]
FAQ: What is the Relationship Between Roots and Coefficients in a Quadratic Equation?
What is (Root)^2 + (Root)^2?
(Root)^2 + (Root)^2 is an expression in algebra that involves taking the square of a root and adding it to the square of another root.
What is the value of (Root)^2 + (Root)^2?
The value of (Root)^2 + (Root)^2 depends on the specific values of the roots. It cannot be simplified further without knowing the specific roots.
What is the purpose of using (Root)^2 + (Root)^2 in scientific research?
(Root)^2 + (Root)^2 is commonly used in scientific research to represent complex mathematical relationships and to solve equations involving square roots.
Is (Root)^2 + (Root)^2 the same as (2Root)^2?
No, (Root)^2 + (Root)^2 and (2Root)^2 are not the same. In (Root)^2 + (Root)^2, the roots are added together, while in (2Root)^2, the entire expression is squared.
Can (Root)^2 + (Root)^2 be simplified further?
It depends on the specific values of the roots. In some cases, (Root)^2 + (Root)^2 may be able to be simplified using algebraic methods, but in others, it may not be possible.
