Graduate What Is the Role of 'n' and the Virgule in the Wedge Product Formalism?
  • Thread starter Thread starter Bill_1
    Permutation
The discussion clarifies the use of the wedge operator in differential geometry, which represents the exterior product of differential forms and is anti-commutative. The "n" in the expression refers to the dimension of the vector spaces involved. The concept of the "virgule" is linked to indices in the context of the wedge product, rather than permutations or combinations. The properties of the wedge product include bilinearity and the fact that it results in zero when applied to linearly dependent vectors. Understanding these concepts is essential for grasping the wedge product formalism in geometric algebra.
Bill_1
TL;DR
Formalism of wedge product
Hi guys!
I have some difficulty to correctly understand the following formalism.
Specifically the using of virgule and the "n" in aink expression.
Does the virgule have some rapport with permutation or combination?
And what represent the n in the expression?
Here you can find the book: https://www2.tulane.edu/~ftbirtel/wedge product.pdf
Thanks for your help!
are you referring to the wedge operator ^ as a virgule?
It's not. The wedge operator is a real operator used in differential geometry to represent the exterior product between two differential forms.
It's an anti-commutative operator, i.e., a^b = - b^a, where a and b are differential forms of the same type.
https://en.wikipedia.org/wiki/Exterior_algebra
Your formula is simple the distributive law, or the bilinear property of the wedge product:
(\vec{a}+\vec{b})\wedge (\vec{c}+\vec{d}) = \vec{a}\wedge (\vec{c}+\vec{d})+\vec{b}\wedge (\vec{c}+\vec{d})=\vec{a}\wedge \vec{c}+\vec{a}\wedge \vec{d}+\vec{b}\wedge \vec{c}+\vec{b}\wedge \vec{d}
and the anti-kommutativity ##a\wedge b=-b\wedge a## that allows us to sort the vectors at the cost of one minus sign per permutation. ##n## is the dimension of the vector spaces where the ##v_j## and basisvectors ##e_k## were taken from. And of course
\vec{v}\wedge \alpha\vec{w}=\alpha\vec{v}\wedge \vec{w}\, , \,(\alpha \in \mathbb{R})
Note that ##\vec{v}\wedge \vec{v}=0.## The wedge product over linearly dependent vectors is zero.
I think the " virgule", which means " comma" in French, represents indices and subindices in your pic. The wedge operator is part of Geometric Algebra, where you glue objects together ( parallelepipeds), to build larger objects. Why don't you look it up and ask followups?
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
10K
  • · Replies 40 ·
