What is the role of surface currents in Ampere's Law with H fields?
In summary, the conversation is about the derivation of Ampere's law as it applies to the auxiliary field H. The person is wondering if surface currents should be included in the integral of H over a loop, and if so, should bound surface currents also be included. The person also asks about the distinction between bound and free currents and how they relate to surface currents. The other person explains that H is introduced so that Ampere's law includes only free currents and that surface currents do not cut through the surface.
McLaren Rulez
292
I'm using Griffiths Electrodynamics and I can't figure out something. For reference, this is on page 269 of the third edition.
In the derivation for Ampere's law as it applies to the auxillary field H (i.e integral of H over a loop = free current passing through), there seems to be no word on the surface currents. If I had an Amperian loop that cut through the boundary between two surfaces, shouldn't we also include the bound surface current Kb along with whatever free current passes through that loop?
Thank you, in advance.
H is introduced so that Ampere's law with H includes only free currents.
You said, free currents. So why include bound currents?
Bounded or not, surface current is on the surface, it does not cut through the surface, right? So the surface current whether it is bounded or free don't cut through the surface ( or the current don't string the Amperian loop.).
Hello, thank you for your question. In the derivation for Ampere's law involving the auxiliary field H, the surface currents are taken into account through the use of the divergence theorem. The integral of the H field over a closed loop is equal to the sum of the free current passing through the loop and the surface current density integrated over the surface enclosed by the loop. This is because the surface current density is related to the bound volume current by the divergence of the H field. Therefore, in this formulation, the surface current is already accounted for and does not need to be explicitly included in the integral. I hope this helps clarify any confusion.
FAQ: What is the role of surface currents in Ampere's Law with H fields?
What is Ampere's Law with H fields?
Ampere's Law with H fields is a fundamental law in electromagnetism that describes the relationship between the magnetic field, current, and the distance around a closed loop. It states that the magnetic field around a closed loop is directly proportional to the current passing through the loop and the distance around the loop.
How is Ampere's Law with H fields different from Ampere's Law with B fields?
Ampere's Law with H fields is a modified version of Ampere's Law with B fields. The main difference is that Ampere's Law with H fields takes into account the magnetic field intensity, or H-field, while Ampere's Law with B fields only considers the magnetic flux density, or B-field. This means that Ampere's Law with H fields is more accurate and applicable in situations where the magnetic properties of a material are taken into account.
What are the applications of Ampere's Law with H fields?
Ampere's Law with H fields has many practical applications in electromagnetism. It is used to calculate the magnetic field around a current-carrying wire, inductor, or solenoid. It is also used in the design of electric motors, transformers, and other devices that utilize magnetic fields.
How is Ampere's Law with H fields derived?
Ampere's Law with H fields is derived from Maxwell's equations, which are a set of four fundamental equations that describe the behavior of electric and magnetic fields. It is specifically derived from the fourth equation, known as Ampere's Law, by incorporating the concept of magnetic field intensity and accounting for the effects of magnetic materials.
What are the limitations of Ampere's Law with H fields?
While Ampere's Law with H fields is a powerful tool in electromagnetism, it does have some limitations. It assumes that the magnetic field is uniform and does not take into account the effects of changing electric fields or time-varying magnetic fields. Additionally, it is not applicable for materials that exhibit nonlinear magnetic properties.
