What is the rotational velocity of hard disk actuator arm?
In summary: All modern CMOS sensor cameras use the rolling shutter system and when doing video of lightning, it totally destroys the image as you can see and often even wore than that.I am still using a 2007 yr Fuji S9500 CCD sensor camera that uses the "global shutter" systemand the lightning strike doesn't get chopped upin video mode, the mechanical shutter stays open and the rolling shutter system just scrolls / collects a horizontal band of signal from the sensorin the CCD sensor cameras ( video mode), even the one I bought in 2012, the global shutter system just switches of signal collection from the full sensor every 30 sec or whatever the frame rate isAs a result, the image
rkatcosmos
0 down vote favorite
There is a lot of material discussing the rotational speed of the magnetic disk in HDD but not about the rotational speed of actuator arm.
What are the typical actuation speeds of the actuator in HDD?
This information will be used in the design of a fast shutter system made by salvaging the HDDD actuator arm.
From reference 9 in hte article you referenced: http://pcguide.com/ref/hdd/perf/perf/spec/posSeek-c.html
Full Stroke: This number is the amount of time to seek the entire width of the disk, from the innermost track to the outermost. This is of course the largest number, typically being in the 15 to 20 ms range. In some ways, combining this number with the average seek time represents the way the drive will behave when it is close to being full.
A look at the specs of a random drive on the Western Digital site showed a diagnostic report of 21ms full stroke.
Likes jim hardy
If that is the time to move from stationary at the inner track to stationary at the outer track, presumably the peak speed will be significantly larger than the average speed you'd get from this.
Though, if it is to be used as a shutter, you may want the time rather than the speed.
And in that case, you may not need the deceleration phase. Just bring it to a hard stop mechanically.
Presumably the coil can run potentially almost continually during heavy disc activity, so perhaps you could significantly overdrive it for occasional snaps, unless you want it for movies.
davenn said:
did you mean to post this somewhere else ??
Thanks for the 'Heads Up' but, no, it's in the intended place. See post #1
ohhhh my bad ... missed the shutter bit in post #1 :rolleyes:
Likes Tom.G
as an aside ...
I abhor those "rolling shutters" used on cameras these days as shown in your first link
scroll down to the lightning photo and the banded light and dark
As a result, the image doesn't get chopped upDave
Related to What is the rotational velocity of hard disk actuator arm?
1. What is rotational velocity?
Rotational velocity refers to the speed at which an object rotates around a central axis.
2. How is rotational velocity measured?
Rotational velocity is typically measured in revolutions per minute (RPM) or radians per second (rad/s).
3. Why is rotational velocity important for hard disk actuator arms?
The rotational velocity of a hard disk actuator arm determines how quickly it can access data on the hard disk. A higher rotational velocity means faster access times and better performance.
4. What is the typical range of rotational velocity for hard disk actuator arms?
The typical range of rotational velocity for hard disk actuator arms is between 5,400 RPM and 15,000 RPM.
5. Can rotational velocity be changed?
Yes, rotational velocity can be changed by adjusting the speed of the motor that drives the hard disk. However, this may also affect the overall performance and lifespan of the hard disk.
  • Electrical Engineering
16K
22K
  • Mechanical Engineering
36K
  • Other Physics Topics
  • Earth Sciences
