What is the scalar product V_1(DOT)V_2 ?
The discussion focuses on calculating the scalar product of two vectors, V_1 and V_2. V_1 points along the z-axis with a magnitude of 80, while V_2 lies in the xz plane with a magnitude of 51, making a -49° angle with the x-axis. Participants emphasize the importance of finding the x, y, and z components of each vector to apply the scalar product formula. After guidance on visualizing the vectors, the correct final answer for the scalar product is determined to be -3079.2. The conversation highlights the utility of vector component analysis in solving the problem.
Rellsun
Vector V_1 points along the z axis and has magnitude V_1 = 80. Vector V_2 lies in the xz plane, has magnitude V_2 = 51, and makes a -49o angle with the x-axis (points below x axis)
A.B=ABCos(theta)=AxBx+AyBy+AzBz
Cos(theta)=(AxBx+AyBy+AzBz)/AB
im not really sure where to go from here I am not sure if those equations are useful
The equations are indeed useful. Find the x,y and z components of each vector, then apply the first equation that you posted.
ok that helps a lot i don't know why i did do that. but how do you find the z component of the V_2=51?
Draw yourself two axes in the plane of the paper. Label the horizontal one x and the vertical one z (instead of the usual y). Draw the vector as indicated. Can you find its x and z components?
ahh thanks that makes much more sense. i got the final answer to be -3079.2 which is indeed correct. the help is appreciated.
28K
  • · Replies 24 ·
9K
