Varon
- 548
- 1
According to Richard Feynman, the double-slit experiment contains the only mystery of quantum mechanics. After we have unveiled the mystery, we will be able to understand quantum mechanics.
Someone has allegedly solved the double slit mystery and unveiled the secret of Quantum Mechanics.
It goes like this.
Initially the emitter emits one electron which is really n electron quantum field which we can say is like a wave. When it reaches the slits, the electron quantum field splits in two. But how come the detector only detects one electron. The secret is that the detector contains many electrons as ingredients in the detection. So what happens is the quantum field or wave simultaneously inpinge on all area of the detector at once.. and one electron in the detector is triggered! This made us assume that this one electron triggered is the same one as the initial electron sends off. But it is not! Herein lies the solution to the 80 year old mystery of the double slit experiment! So claimed Arnold Neumaier. For details. See this thread in Independent Research.
https://www.physicsforums.com/showthread.php?t=490492
Now some basic questions.
Is it true that all detectors have electrons as their ingredients in the detection event? We know photosensor has electron and photoelectric effect has to do with the electrons in the detector. So the secret of the double slit is the emitter didn't send a solid particle with a classical trajectory to either slit. But pure quantum wave that splits after reaching the slits and then trigger one of the electrons in the detector. But why only one detector is triggered.
Neumaier explained:
I asked: "After it pass thru the slits, it became smeared. Now how does the smeared field converge back into a single electron detected at the screen?"
Neumaier answered:
Questions:
Can anyone think of detectors that don't use electrons? Or think of a unique setup that can refute the above theory? Double slit experiment is very basic and this is why I post it here.
It goes like this.
Neumaier explained:
The electron is always a quantum field. The quantum field can be regarded to describe a particle if and only if the field has a nonzero expectation only in a region small compared to the whole system considered. Thus we may say that the field is a particle as long as this condition is satisfied. Because of the dispersion of the field caused by the slits, this condition stops to be satisfied almost immediately after the field (with support large enough to cover both slits) passed the double slit. Thus it is no longer justified to talk about a particle.
The situation is similar as with a sphere of glass. If you throw it, you may regard it as a particle. But if it hits an obstacle and fragmentizes, it is no longer localized enogh to deserve the name of a particle.
The field passes the doulbe slit in a fashion similar as a water wave would do, except with quantum corrections."
Neumaier answered:
It doesn't. It remains smeared. But one of the electrons in the detector fires and
(after magnification) gives rise to a measurable current.. This will happen at exactly one place. Thus it _seems_ that the electron has arrived there, while in fact it has arrived everywhere within its extent.
If a water wave reaches a dam with a hole in it, the water will come out solely through this hole although the wave reached the dam everywhere. A detector is (in a vague way) similar to such a dam with a large number of holes, of which only one per electron can respond because of conservation of energy.
Questions:
