- #36
Bandersnatch
- 3,036
No. Not only there's no force anywere in there, there's no distance of 1m either. You have plugged in the distance between Earth and Moon for R yourself, so wherefrom the idea that it's now 1m?You say you want to calculate Earth-Moon gravitational attraction. What you should be calculating then is a force. You could either use the Newton's force of gravity equationbobie said:This is the force of attraction of the Earth at distance 1 m, correct?
[itex]F=GMm/R^2[/itex]
or make use of the fact of Moon being on a low-eccentricity(nearly circular) orbit and calculate the centripetal force
[itex]F=mV^2/R[/itex]
There's no use in comparing the two equations, since you're supplying all the values. You just plug in the numbers and get the force.
Writing an identity of [itex]GMm/R^2=mV^2/R[/itex] is useful if you're missing some value and want to find it.
You can solve the above for V, R, M, or even G, if that's what you're missing. But you won't be calculating the force anymore.
What you wrote here:
is the calculation of the value of [itex]GM[/itex], that you then check by plugging in the numbers for these well-known constants. What is [itex]GM[/itex]? Beats me. It's got no particular physical meaning, even though it's numerical value happens to be equal to [itex]GMm/R^2[/itex] where m and R are chosen to both be equal to 1(which, by the way, means it would require a black hole for the mass of Earth to be contained within 1m sphere to produce such a force). They are not the same, though, as can be shown by using unit calculus. Even though both R and m are 1, they still have their units of m and kg, so the resultant units is the Newton, as it should be for the Force of gravity, while [itex]GM[/itex] has units of [m^3/s^2].GM = m*v2*r {This is not a valid identity, by the way. You left the m when it ought to have canceled out}
v2(10222 m/s = 1044484) * r (3.844*108 m) = 4.015*1012{and here the units don't match. The unit of V^2 is (m/s)^2, not m/s}
G(6.674*10-11) * M(5.9722*1024 Kg) = 3.986*1012{here you wrote the unit for mass but not for G. But then again, just as previously, you don't follow with calculating units for the result on the right-hand side of the equation.}
So, once again, you're not calculating any forces there.
A word of advice for solving any equations - first pick the appropriate equation. You need to understand what it means and when it's applicable. Throwing equations around without any purpose or plan is not going to work.
Next, identify what is the one thing you want to find, and isolate it one side. You know what you're looking for, so it should be easy. If it's not there, or is cancelling out, then you've got the wrong equation.
Then plug in the units only, for the variables and constants on the other side to find out whether the resultant unit matches the unit for the thing you're solving the equation for. If it doesn't(e.g., a force is not in Newtons, mass in not in kilograms), it means you borked the arithmetics, or have isolated the wrong variable for some reason.
Only then plug in the actual numbers to get the final answer. If you happen to use two or more different methods(i.e., equations) to calculate the same thing, and the results slightly don't match, then you may want to examine the assumptions that came with writing the equations, to decide which one is closer to the true value.
