What is the size of a black hole?
In summary, the conversation discusses the concept of the Planck length and its relation to black holes. It is suggested that according to string theories, a black hole's center would be limited to the Planck size and not a true singularity as predicted by general relativity. However, the exact size of a black hole's center is still unknown and may require a theory of quantum gravity to determine. Additionally, it is noted that the term "singularity" is used to indicate a lack of understanding in mathematical terms.
dida
If Planck length is the smallest size, does that mean a black hole would get compressed down to the Planck scale, but no further or can the black hole really have zero size like an electron?
According to many string theories, the Planck size is the limit---and thus a BH's center would indeed be about that size, and not a true singularity (as general relativity suggests). The answer is unknown.
Side-notes:
1) Black-hole refers to the entire object, specifically the event horizon---not just the central singularity
2) Electrons have a finite (non-zero) size.
The term 'singularity' is math speak for 'we don't know'. It is the point where our math ceases to yield intelligible results. We know the chunk of matter hiding behind an event horizon is smaller than the event horizon [duh]. A good guess would be some multiple of Planck lengths, but, that is still just a guess. We probably need a theory of quantum gravity to get the right answer.
Related to What is the size of a black hole?
1. What is the size of a black hole?
The size of a black hole varies depending on its mass. The more mass a black hole has, the larger its event horizon, which is the point of no return for anything that enters the black hole's gravitational pull. The event horizon can range from a few kilometers to billions of kilometers in diameter.
2. How is the size of a black hole measured?
The size of a black hole is typically measured by its event horizon, which can be calculated using the black hole's mass and its Schwarzschild radius. The Schwarzschild radius is the distance from the center of the black hole where the escape velocity equals the speed of light.
3. Can the size of a black hole change?
Yes, the size of a black hole can change over time. As a black hole consumes matter, its mass and event horizon will increase. Additionally, black holes can merge with other black holes, resulting in a larger black hole.
4. Is there a limit to how large a black hole can be?
There is no known size limit for black holes. As long as a black hole continues to consume matter, its size can continue to increase. However, there is a theoretical limit known as the Eddington limit, which is the maximum amount of mass a black hole can have before its radiation outflow overcomes its gravitational pull.
5. Are all black holes the same size?
No, black holes can vary in size depending on their mass. There are three main types of black holes: stellar black holes, intermediate black holes, and supermassive black holes. Stellar black holes can range from a few solar masses to tens of solar masses, while supermassive black holes can have masses equivalent to billions of suns.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
