What Is the Smallest Integer $a$ for $\frac{1}{640}=\frac{a}{10^b}$?
  • MHB
  • Thread starter anemone
In summary, the smallest integer solution for 1/640 = a/10^b - POTW is a = 1 and b = 6. To determine the solution for this equation, you can use algebraic manipulation by multiplying both sides by 640 and then by 10^b. This equation has only one solution, making the smallest integer solution unique. This type of equation is commonly encountered in scientific research, particularly in fields such as mathematics, physics, and engineering. However, there are also other types of equations that have a single, unique solution, such as linear, quadratic, and exponential equations.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Find the smallest value of $a$ such that $\dfrac{1}{640}=\dfrac{a}{10^b}$, where $a$ and $b$ are integers.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution: (Smile)
1. Ackbach
2. kaliprasad
3. castor28
Solution from Ackbach:
We have
$$a=\frac{10^b}{640}=\frac{10^{b-1}}{64}=\frac{10\cdot 10^{b-2}}{64}=\frac{5\cdot 10^{b-2}}{32}
=\frac{5^2\cdot 10^{b-3}}{16}=\dots=5^6\cdot 10^{b-7}. $$
Hence, for $5^6\cdot 10^{b-7}$ to be an integer, we need $b\ge 7$; the smallest such $b$ is $7$, which makes $a=5^6$.
FAQ: What Is the Smallest Integer $a$ for $\frac{1}{640}=\frac{a}{10^b}$?
What is the smallest integer solution for 1/640 = a/10^b - POTW?
The smallest integer solution for 1/640 = a/10^b - POTW is a = 1 and b = 6.
How do you determine the solution for this equation?
To determine the solution for 1/640 = a/10^b - POTW, you can use the following steps:
  1. Multiply both sides of the equation by 640 to eliminate the denominator on the left side.
  2. Then, multiply both sides by 10^b to eliminate the denominator on the right side.
  3. Solve for a and b using algebraic manipulation.
Can there be multiple solutions for this equation?
No, there can only be one solution for this equation since the smallest integer solution is unique.
How does this equation relate to scientific research?
This equation is an example of a mathematical problem that may arise in scientific research, particularly in the fields of mathematics, physics, and engineering. It involves using algebraic principles to solve for unknown variables, which is a fundamental skill in scientific research.
Are there any other types of equations that have a single, unique solution?
Yes, there are many other types of equations that have a single, unique solution. These include linear equations, quadratic equations, and exponential equations, among others.
