What Is the Smallest k for a Cubic Function to Have Exactly One Real Root?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the smallest k for a unique real root of a cubic function is the minimum value of the variable k that will result in a distinct solution for the equation. It is important because it helps determine the range of values for k that will give a unique real root, and it can be calculated using various methods such as the cubic formula or discriminant method. If there is no smallest k, it means there is no value of k that will result in a unique real root, and in this case, alternative methods may need to be used. The smallest k can be a negative number, as it is dependent on the coefficients of the cubic function and can take on any real number value.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Compute the smallest value $k$ such that for all $n>k$, the cubic function $x^3+x^2+nx+9$ has exactly one real root.-----
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week's problem.(Sadface)
You can find the suggested solution below:
In order to compute the smallest value $k$ such that for all $n>k$, the cubic function $x^3+x^2+nx+9$ has exactly one real root, we first let $f(x)=x^3+x^2+nx+9$ has a negative root $a$ and a double root $b$.
By the Vieta's formula, we have:
$ab^2=-9$
$a+2b=-1$
Solving them for $b$, we get
$2b^3+b^2-9=0\\ \therefore (2b-3)((b+1)^2+2)=0$
This means $b=\dfrac{3}{2}$ is the only real solution of $f(x)$ so $a=-4$.
This gives $p=-\dfrac{39}{4}$.
FAQ: What Is the Smallest k for a Cubic Function to Have Exactly One Real Root?
What is the meaning of "Smallest k for unique real root of cubic function"?
The "smallest k" refers to the smallest value of the variable k in the cubic function that will result in a unique real root. In other words, it is the minimum value of k that will give a distinct solution for the equation.
Why is finding the smallest k for unique real root of cubic function important?
Finding the smallest k is important because it helps us determine the range of values for k that will give us a unique real root. This information can be useful in various applications, such as in engineering and physics problems.
How is the smallest k for unique real root of cubic function calculated?
The smallest k can be calculated using various methods, such as the cubic formula or the discriminant method. These methods involve substituting the coefficients of the cubic function into a formula to determine the value of k.
What happens if there is no smallest k for unique real root of cubic function?
If there is no smallest k, it means that there is no value of k that will result in a unique real root. This could happen if the cubic function has multiple real roots or no real roots at all. In this case, other mathematical methods may need to be used to find solutions for the equation.
Can the smallest k for unique real root of cubic function be a negative number?
Yes, the smallest k can be a negative number. The value of k is dependent on the coefficients of the cubic function, so it can take on any real number value, including negative numbers.
