What Is the Smallest Multiple of 2013 That Solves This System of Equations?
  • MHB
  • Thread starter anemone
  • Tags
    Multiple
In summary, the "least multiple" in this context refers to the smallest number that is a multiple of two given numbers. To find the least multiple of two numbers, you can use the prime factorization method or the Least Common Multiple (LCM) formula. The LCM is always a whole number and is inversely related to the greatest common factor (GCF). The concept of least multiple can also be extended to more than two numbers.
anemone
MHB
POTW Director
3,883
115
Find the least multiple $k$ of $2013$ for which the system of equations
$(a^2+b^2)(b^2+c^2)(c^2+a^2)=a^6+b^6+c^6+4k^2$
$abc=k$
has a solution.
Mathematics news on Phys.org
If \(\displaystyle a\), \(\displaystyle b\) and \(\displaystyle c\) are the members of a Pythagorean triple, the system of equations has a solution.
The smallest \(\displaystyle abc\) which is a multiple of 2013 is (11, 60, 61) -- minimal \(\displaystyle k\) is 20 * 2013 = 40260.
Thanks for participating, greg1313! Your answer is correct!
$abc=k$
has a solution.
Solution of other:
$a^6+b^6+c^6+4(abc)^2-(a^2+b^2)(b^2+c^2)(c^2+a^2)=(a^2-b^2-c^2)(a^2+b^2-c^2)(a^2-b^2+c^2)$
Therefore we get:
$(a^2-b^2-c^2)(a^2+b^2-c^2)(a^2-b^2+c^2)=0$
And deduce that either $a^2-b^2-c^2=0$ or $a^2+b^2-c^2=0$ or $a^2-b^2+c^2=0$.
This means $(a,\,b,\,c)$ is a Pythagorean triple and is therefore of the form $(u^2-v^2,\,2uv,\,u^2+v^2)$ for certain integers $u$ and $v$.
So,
$abc=k=n(2013)=n(3)(11)(61)=(u^2-v^2)(2uv)(u^2+v^2)=(2uv)(u-v)(u+v)(u^2+v^2)$
One easily verifies that the least multiple of $2013$ for which the above equation holds is $k=20(2013)=40260$, with $u=6$ and $v=5$.
FAQ: What Is the Smallest Multiple of 2013 That Solves This System of Equations?
What does "least multiple" mean in this context?
The "least multiple" in this context refers to the smallest number that is a multiple of two given numbers, also known as the least common multiple.
How do I find the least multiple of two numbers?
To find the least multiple of two numbers, you can use the prime factorization method or the Least Common Multiple (LCM) formula. The LCM is the smallest number that is divisible by both given numbers without leaving a remainder.
Can the least multiple be a decimal or a fraction?
No, the least multiple is always a whole number. If the result of finding the least multiple is a decimal or a fraction, you can multiply it by a whole number to get the smallest whole number that is a multiple of the two given numbers.
What is the relationship between the least multiple and the greatest common factor (GCF)?
The least multiple and the greatest common factor (GCF) are inversely related. This means that if you multiply the least multiple and the GCF together, you will get the product of the two given numbers.
Can I find the least multiple of more than two numbers?
Yes, the concept of least multiple can be extended to more than two numbers. To find the least multiple of three or more numbers, you can use the LCM formula or find the prime factorization of each number and then multiply the highest powers of the common prime factors.
