What is the Smallest Possible Value of a in This Polynomial Pattern?
  • MHB
  • Thread starter anemone
In summary, to find the minimum value of a polynomial with integer coefficients, you can use methods such as factoring, completing the square, or the first derivative test. The purpose of finding the minimum value is to gather important information about the polynomial's behavior and it can be used to solve optimization problems or find the roots. The minimum value can be negative and can also be a decimal or fraction due to the coefficients being any integer. Specific techniques such as the Rational Root Theorem, Quadratic Formula, or using technology can aid in finding the minimum value.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a>0$ and $P(x)$ be a polynomial with integer coefficients such that
$P(1)=P(3)=P(5)=P(7)=a$ and
$P(2)=P(4)=P(6)=P(8)=-a$.
What is the smallest possible value of $a$?
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg for his partial correct solution!(Cool)
You can find the suggested solution as shown below:
Because 1, 3, 5 and 7 are roots of the polynomial $P(x)-a$, it follows that
$P(x)-a=(x-1)(x-3)(x-5)(x-7)Q(x)$,
where $Q(x)$ is a polynomial with integer coefficients. The identity must also hold for $x=2,\,4,\,6$ and $8$, thus,
$-2a=-15Q(2)=9Q(4)=-15Q(6)=105Q(8)$
Therefore $315=\text{lcm} (15,\,9,\,105)$ divides $a$, that is $a$ is an integer multiple of 315.
Let $a=315A$. Because $Q(2)=Q(6)=42A$, it follows that $Q(x)-42A=(x-2)(x-6)R(x)$, where $R(x)$ is a polynomial with integer coefficients.
Because $Q(4)=-70A$ and $Q(8)=-6A$, it follows that $-112A=-4R(4)$ and $-48A=12R(8)$, that is $R(4)=28A$ and $R(8)=-4A$.
Thus, $R(x)=28A+(x-4)(-6A+(x-8)T(x))$, where $T(x)$ is a polynomial with integer coefficients.
Moreover, for any polynomial $T(x)$ and any integer $A$, the polynomial $P(x)$ constructed this way satisfies the required conditions. The required minimum is obtained when $A=1$ and so $a=315$.
FAQ: What is the Smallest Possible Value of a in This Polynomial Pattern?
What is the definition of a polynomial?
A polynomial is a mathematical expression consisting of variables and coefficients, combined using the operations of addition, subtraction, and multiplication. It can have one or more terms, with each term being a combination of a constant coefficient and a variable raised to a non-negative integer power.
How do you find the minimum value of a polynomial with integer coefficients?
To find the minimum value of a polynomial with integer coefficients, you can use a variety of methods such as graphing, factoring, or using the derivative. However, the most efficient method is to use the Rational Root Theorem to determine the possible rational roots, and then use synthetic division to test each root until the minimum value is found.
What is the Rational Root Theorem?
The Rational Root Theorem states that any rational root of a polynomial with integer coefficients must be in the form of p/q, where p is a factor of the constant term and q is a factor of the leading coefficient. This theorem is useful in finding the possible rational roots of a polynomial, which can then be tested using synthetic division.
Can a polynomial have more than one minimum value?
No, a polynomial can only have one minimum value. This is because the graph of a polynomial is a smooth curve, and the minimum point is the lowest point on this curve. Therefore, there can only be one point with the lowest y-value, which is the minimum value of the polynomial.
How can finding the minimum value of a polynomial be useful?
Finding the minimum value of a polynomial can be useful in various applications, such as optimization problems in economics, engineering, and science. It can also help in finding the roots of a polynomial, as the minimum value is often associated with the x-value of the root. Additionally, knowing the minimum value can provide insight into the behavior of the polynomial and its graph.
