MHB What is the smallest side length BC of triangle ABC with fixed angle and area?
  • Thread starter Thread starter maxkor
    Length
To determine the smallest side length BC of triangle ABC with a fixed angle BAC equal to alpha and a fixed area S, the area formula is used: S = (1/2) * a^2 * (sin β * sin γ) / sin α. To minimize side BC (a), it is essential to maximize the expression 2 * sin β * sin(α + β). Calculus indicates that the maximum occurs when β equals γ, making the triangle isosceles. The resulting minimum value for BC is given by the formula a = √(2S * sin α) / cos(α/2). This provides a clear relationship between the triangle's dimensions and its fixed properties.
maxkor
Calculate what is the smallest side length BC of the triangle ABC if the angle BAC is equal alpha and area of the triangle ABC equals S.
Mathematics news on Phys.org
Are we to assume that ABC is a right triangle?
Suppose that angle $$\alpha$$ is fixed and that the area of $$\triangle ABC = S$$ is fixed. We wish to find the smallest value of side $$BC=a$$.
If the other two angles are $$\beta$$ and $$\gamma$$ then $$\alpha + \beta + \gamma = 180$$ and $$\gamma = 180 - (\alpha+\beta)$$.
The area of $$\triangle ABC$$ is $$S = \dfrac{1}{2}a^2 \cdot \dfrac{\sin \beta \sin \gamma}{\sin \alpha}$$.
So we have that $$a^2 = \dfrac{2S \sin \alpha}{\sin \beta \sin \gamma} = \dfrac{4S \sin \alpha}{2\sin \beta \sin (\alpha+\beta)}$$.
To minimize $$a$$ we must maximize $$2\sin \beta \sin (\alpha+\beta)$$.
$$y = 2\sin \beta \sin (\alpha+\beta) = \cos \alpha - \cos(\alpha+2\beta)$$.
Standard calculus yields a maximum when $$\alpha+2\beta=180$$. That is, when $$\beta=\gamma$$ and the triangle is isosceles.
Substituting back, the minimum value of $$BC = a$$ = $$\dfrac{\sqrt{2S \sin \alpha}}{\cos \left(\dfrac{\alpha}{2}\right)}$$.
... I think!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
