What is the solution for t when $-0.1143e^{-\frac{2t^2}{3}}= -199$?
In summary: Multiply both sides by $e^{\frac{2t^2}{3}}$ to get $-0.1143= -199e^{\frac{2t^2}{3}}$.Divide by $-199$ to et $0.0005733678= e^{\frac{2t^2}{3}}$. Take the natural log of both sides: $ln(0.0005733678)= \frac{2t^2}{3}$. Multiply both sides by $\frac{3}{2}$: $\frac{3}{2}ln(0.0005733678)= t^2$. Take the square root of both sides: $t= \
karush
MHB
3,269
$y'=ty\dfrac{4-y}{3};\quad y{0}=y_0$
separate
$\dfrac{3}{y(4-y)}\ dy=t\ dt$
integrate
$3\left(\frac{1}{4}\ln \left|y\right|-\frac{1}{4}\ln \left|y-4\right|\right)=\dfrac{t^2}{2}+c$
hopefully so far...
actually it kinda foggy what they are eventually asking for
also why is t in different cases
Yes, that is correct so far! Now, you might use the facts that $rlog(x)= log(x^r)$ and $log(a)- log(b)= log(a/b)$. And you can get rid of the logarithm by taking the exponential on both sides.
for some reason your latex didn't render with [tex] I thot it was supposed to be \(\displaystyle {/math] or $$
I assume the 3 has to distributed and an exponent\)
Write it as $\frac{3}{4}log\left|\frac{y}{y- 4}\right|= t^2/2+ c$
$log\left|\frac{y}{y- 4}\right|= \frac{2}{3}t^2+ C$
$\frac{y}{y- 4}= C'e^{\frac{2t^2}{3}}$
And, with $y(0)= y_0$, $\frac{y_0}{y_0- 4}=C'$.
so $\frac{y}{y- 4}= \frac{y_0}{y_0- 4}e^{\frac{2t^2}{3}}$.
ok here is the book answer to (b)
assume various inputs were tried to get to 3.98
Part (b) told you that $x_0= 0.5$ so $\frac{y_0}{y_0-4}= \frac{0.5}{0.5- 4}= \frac{0.4}{-3.5}= -.01143$.
$\frac{y}{y- 4}= -0.1143e^{\frac{2t^2}{3}}$.
We want y to be 3.98 so $\frac{y}{y- 4}= \frac{3.98}{3.98- 4}= -\frac{3.98}{0.02}= -199
Solve $-0.1143e^{-\frac{2t^2}{3}}= -199$.
FAQ: What is the solution for t when $-0.1143e^{-\frac{2t^2}{3}}= -199$?
What is "IVP" in relation to behavior?
"IVP" stands for "initial value problem" and is a mathematical concept used to describe the behavior of a system over time. In the context of behavior, an initial value problem would refer to the initial state or conditions of a person's behavior and how it changes over time.
How is "-b.2.2.27" related to behavior?
The "-b.2.2.27" notation is not directly related to behavior. It could potentially refer to a specific behavior code or category used in a particular research study or system. Without more context, it is difficult to determine its exact meaning.
What does "t" represent in "-b.2.2.27 IVP t behavior"?
"t" typically represents time in mathematical equations, so in this context, it would likely refer to the time component of a behavior's initial value problem. It could also potentially refer to a specific time point or interval being studied in relation to behavior.
How does "-b.2.2.27 IVP t behavior" apply to real-life situations?
The concept of an initial value problem in relation to behavior can be applied to real-life situations by understanding how a person's behavior may change over time based on their initial conditions or circumstances. For example, a person's behavior may be influenced by their upbringing, environment, and experiences, and these initial factors can shape their behavior over time.
What is the significance of "-b.2.2.27 IVP t behavior" in the field of science?
In the field of science, "-b.2.2.27 IVP t behavior" could refer to a specific mathematical model or equation used to study behavior. It could also represent a particular research study or theory that focuses on understanding the initial conditions and changes in behavior over time. Overall, it highlights the importance of considering the initial state or conditions of a system when studying its behavior.
