What is the solution for x in the equation 1.4x + 9 = -2?
  • MHB
  • Thread starter karush
In summary, the conversation involves row reduction of a given matrix using W|A and solving for the values of x, y, and z using back substitution. The final solution is x = -11, y = 3, z = 0.
karush
MHB
3,269
Ok I'm doing 11 and 12
I kept trying row reduction but no
W|A
https://www.physicsforums.com/attachments/8751
Row reduction:
$\begin{bmatrix}1 & 3 & -4 \\ 1 & 5 & 2 \\ -3 & -7 & 6 \end{bmatrix}\begin{bmatrix}-2 \\ 4 \\ 12 \end{bmatrix}$
Subtract the first row from the second row and add 3 times the first row to the third row:
$\begin{bmatrix}1 & 3 & -4 \\ 0 & 2 & 6 \\ 0 & 2 & -6 \end{bmatrix}\begin{bmatrix}-2 \\ 6 \\ 6 \end{bmatrix}$
Subtract the second row from the third row:
$\begin{bmatrix}1 & 3 & -4 \\ 0 & 2 & 6 \\ 0 & 0 & -12 \end{bmatrix}\begin{bmatrix}-2 \\ 6 \\ 0 \end{bmatrix}$
This is now an "upper triangular" matrix which can be solved by "back substitution". The third row is equivalent to the equation -12z= 0 so z= 0. The second row is equivalent to the equation 2y+ 6z= 6 and since z= 0, 2y= 6, y= 3. The first row is equivalent to x+ 3y- 4z= 2 and since y= 3 and z= 0, x+ 9= 2 so x= -7.
$\textsf{I think $x=-11$,}$
x + 9 = -2 so x = -11.
FAQ: What is the solution for x in the equation 1.4x + 9 = -2?
What does the equation 1.4 Ax=b mean?
The equation 1.4 Ax=b is a linear equation in the form of Ax=b, where A is a matrix and x and b are vectors. The 1.4 in front of the A indicates a scalar multiplication, meaning that every element in the matrix A is multiplied by 1.4.
How do you solve 1.4 Ax=b?
To solve 1.4 Ax=b, you can use the matrix inverse method or Gaussian elimination method. Both methods involve manipulating the matrix A and vector b to find the values of x that satisfy the equation.
What are the steps to solve 1.4 Ax=b using the matrix inverse method?
The steps to solve 1.4 Ax=b using the matrix inverse method are as follows:
1. Find the inverse of matrix A.
2. Multiply both sides of the equation by the inverse of A.
3. Simplify the resulting equation to solve for x.
4. Substitute the values of x back into the original equation to check for accuracy.
What is the purpose of solving 1.4 Ax=b?
The purpose of solving 1.4 Ax=b is to find the values of x that satisfy the equation and make it true. This can be useful in various applications, such as solving systems of linear equations, finding the coefficients in a linear regression model, or solving for unknown variables in physics problems.
Can 1.4 Ax=b have more than one solution?
Yes, 1.4 Ax=b can have more than one solution. This is known as an underdetermined system, where there are more unknown variables than equations. In this case, there are infinite solutions that satisfy the equation. However, if the number of equations is equal to the number of unknown variables, there will be a unique solution.
