What is the solution of the difference equation for this equation?
  • MHB
  • Thread starter juantheron
  • Tags
    Range
In summary, the range of $\displaystyle f(x) = x^2+1+\frac{1}{x^2+x+1}\forall x\in \mathbb{R}$ is $[1.800394, +\infty)$. The minimum value of $f(x)$ can be found by solving the equation $2x^5+4x^4+6x^3+4x^2-1=0$ and finding the limit of the solutions. The conditions for convergence to the solution are also explained.
juantheron
247
Range of $\displaystyle f(x) = x^2+1+\frac{1}{x^2+x+1}\forall x\in \mathbb{R}$
It is clear that $\displaystyle \lim_{x \rightarrow + \infty} f(x) = \lim_{x \rightarrow - \infty} f(x)= + \infty$ so that, the range is defined if we find the absolute minimum of f(x). Proceeding with the standard method the values of x where $f^{\ '}(x)$ vanishes are the root of the equation...
$\displaystyle 2\ x^{5} +4\ x^{4} +6\ x^{3} +4\ x^{2} -1=0$ (1)
The (1) has a single real root in $x_{0} \sim .379093$, so that the minimum is $y_{0}=f(x_{0}) \sim 1.800394$ and the range of f(*) is $[y_{0}, + \infty)$...
Kind regards
$\chi$ $\sigma$
jacks,
if a solver can't do this without using calculus, then this problem should not
be posted under "Pre-Calculus." You would post it under "Calculus."
---------- Post added at 11:07 ---------- Previous post was at 10:57 ----------
chisigma said:
The (1) has a single real root in $x_{0} \sim > > .379093$, < < so that the minimum is $y_{0}=f(x_{0}) \sim > > 1.800394$ < <
My TI-83 gives rounded values of (which when rounded to 6 decimal places) as
0.379095 and 1.800395, respectively.
Yes http://www.mathhelpboards.com/member.php?219-checkittwice next time i will consider it
Thanks chisigma
but how can i calculate the real roots of the equation $2x^5+4x^4+6x^3+4x^2-1=0$
Thanks chisigma
As explained in...
http://www.mathhelpboards.com/showthread.php?426-Difference-equation-tutorial-draft-of-part-I
... the solutions of the equation $\displaystyle \varphi (x)=0$ is the limit [if limit exists...] of the solution of the difference equation...
$\displaystyle \Delta_{n}= a_{n+1}-a_{n}= f(a_{n})\ ;\ f(x)=- \frac {\varphi(x)}{\varphi^{\ '}(x)}$ (1)
... with a proper 'initial value' $a_{0}$ and the conditions about $a_{0}$ for convergence to the solution are also explained...
Kind regards
$\chi$ $\sigma$
FAQ: What is the solution of the difference equation for this equation?
What is the range of a function?
The range of a function refers to the set of all possible output values or y-values that the function can produce given different input values or x-values.
How do you find the range of a function?
To find the range of a function, you can graph the function and identify the highest and lowest points on the graph. The range will then be the set of all y-values between these two points, including the endpoints.
Can a function have an infinite range?
Yes, a function can have an infinite range if it continues to produce new output values as x approaches infinity or negative infinity.
What is the difference between the domain and the range of a function?
The domain of a function refers to the set of all possible input values or x-values, while the range refers to the set of all possible output values or y-values.
Can a function have the same range as its domain?
Yes, a function can have the same range as its domain if it is a one-to-one function, meaning each input value corresponds to only one output value.
