What is the solution to Euler's totient function for a given value of n?
  • MHB
  • Thread starter Chris L T521
In summary, Euler's totient function, also known as the phi function, is a mathematical function that counts the number of positive integers less than or equal to a given integer n that are relatively prime to n. It has many applications in number theory, cryptography, and computer science, and is calculated using the formula phi(n) = n * (1-1/p1) * (1-1/p2) * ... * (1-1/pk), where n is the given integer and p1, p2, ..., pk are its prime factors. The solution to Euler's totient function is always a positive integer and it has an important relationship with prime numbers, as phi(p) = p-1 for any prime number
Chris L T521
MHB
915
Thanks to those who participated in last week's POTW! Here's this week's problem!
Problem: Determine all $n$ for which $\varphi(n)=n-2$, where $\varphi(n)$ denotes Euler's totient function.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was correctly answered by Bacterius, chisigma, and magneto.
You can find Bacterius' solution below.
[sp]Lemma 1: Euler's totient function $\varphi(n)$ is even for all $n > 2$.
Proof: If $n$ is a power of two, then $n = 2^k$ with $k > 1$ (since $n > 2$), and therefore $\varphi(n) = 2^{k - 1} > 1$ is even. If $n$ is not a power of two, then $n$ has at least one odd prime power factor, call it $p^k$ with $k \geq 1$, so $p^k \mid n$. Then $\varphi(p^k) \mid \varphi(n)$, that is, $(p - 1) p^{k - 1} \mid \varphi(n)$. Note $p - 1$ is even. $\blacksquare$
Lemma 2: For all even $n \geq 2$, Euler's totient function satisfies $1 \leq \varphi(n) \leq \frac{n}{2}$.
Proof: Since $n$ is even, rewrite it as $n = 2^k m$ with $k \geq 1$ and odd $m$. Then $1 \leq \varphi(2^k m) = \varphi(2^k) \varphi(m) = 2^{k - 1} \varphi(m) = \frac{1}{2} 2^k \varphi(m) \leq \frac{n}{2}$ by observing that $1 \leq \varphi(m) \leq m$ by definition. The upper bound is attained whenever $n$ is a power of two. $\blacksquare$
Theorem: The only solution to the equation $\varphi(n) = n - 2$ is $n = 4$.
Proof: We first dispose of the special case $n = 1$ by verifying that it is not a solution. We can then eliminate all odd $n$ as solutions in light of Lemma 1, as $\varphi(n) = n - 2$ must be even. We then deduce from Lemma 2 that any (even) solution to the equation for $n \geq 2$ must satisfy $1 \leq n - 2 \leq \frac{n}{2}$, that is, $3 \leq n \leq 4$. It remains to check whether or not $n = 4$ is a solution, and indeed $\varphi(4) = 2$. $\blacksquare$[/sp]
I also liked magneto's solution, so you can see it below as well.
[sp]For an integer $n$ to satisfy $\phi(n) = n-2$,
it means there are two integers $\leq n$ that are not coprime with $n$ --- one of which
we know is $n$. Suppose the other is $m < n$ where $\gcd(m,n) = c > 1$. Then
we know there is an integer $1 < a < n$ where $ac = n$.
If $a \neq c$, since $a,c$ both divide $n$, $\gcd(a,n) \neq 1 \neq \gcd(c,n)$,
implying $\phi(n) < n-2$. Therefore, $a = c$, implying the necessary condition
is that $n$ is a square. We can quickly check that $n=4$ holds: $\phi(4) = 2$,
as $1$ and $3$ are the only two integers $\leq 4$ coprime with $4$.
However, for $k > 2$, we have that $2k < k^2$. So, there are at least three
integers $\leq k^2$ not coprime with $k^2$, namely, $k$, $2k$ and $k^2$,
hence, $\phi(k^2) < k^2 - 2$ for $k > 2$.
$\therefore$ The only $n$ where $\phi(n) = n-2$ is $n=4$.[/sp]
FAQ: What is the solution to Euler's totient function for a given value of n?
What is Euler's totient function?
Euler's totient function, also known as the phi function, is a mathematical function that counts the number of positive integers less than or equal to a given integer n that are relatively prime to n. In other words, it calculates the number of numbers between 1 and n that do not share any common factors with n other than 1.
What is the purpose of Euler's totient function?
Euler's totient function has many applications in number theory, cryptography, and computer science. It is used, for example, in RSA encryption to generate large prime numbers and in the analysis of the complexity of certain algorithms.
How is the solution to Euler's totient function calculated?
The formula for calculating Euler's totient function is phi(n) = n * (1-1/p1) * (1-1/p2) * ... * (1-1/pk), where n is the given integer and p1, p2, ..., pk are its prime factors. Essentially, the solution is found by multiplying n by the product of 1 minus the reciprocal of each prime factor of n.
Can the solution to Euler's totient function be a decimal or fraction?
No, the solution to Euler's totient function is always a positive integer. This is because the function counts the number of positive integers, and the number of integers can never be a decimal or fraction.
What is the relationship between Euler's totient function and prime numbers?
One important relationship between Euler's totient function and prime numbers is that phi(p) = p-1 for any prime number p. This means that for prime numbers, the number of positive integers less than or equal to p that are relatively prime to p is simply p-1. This relationship is used in various mathematical proofs and applications of Euler's totient function.
